PBR switch internal routing
Machi Ma
I am studying PBR now.  With example like
http://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118156-configure-wsa-00.html
copy and rewrite part of config
---------- vlan ip address ------------
interface Vlan10
desc User VLAN 10
ip address 10.1.1.1 255.255.255.0
interface Vlan20
desc User VLAN 20
ip address 10.1.2.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.3.1
---- access-list -----
! match source ip 10.1.1.0/24
access-list 100 permit tcp 10.1.1.0 0.0.0.255 any
! Match source ip 10.1.2.0/24
access-list 101 permit tcp 10.1.2.0 0.0.0.255 any
---- route-map ----
route-map 100traffic permit 100
match ip address 100
set ip next-hop 192.168.1.1
route-map 101traffic permit 100
match ip address 101
set ip next-hop 192.168.2.1
------Apply to Vlan interface ------------------
interface vlan10
ip policy route-map 100traffic
interface vlan20
ip policy route-map 101traffic
Question:
1) I have 2 subnet host 10.1.1.0/24 and 10.1.2.0/24 which connected directly to switch now.  According to above config, it looks will re-route to next-hop first and re-route back to the switch?
2) How can I config inter-vlan switch routing?
Thanks!
Julio E. Moisa
About the question 1, yes that is correct, it will manipulate the traffic to point to a specific next hop, this next hop (layer 3 device) must know how to return the packet to the source, it can be via dynamic routing or static route.
About the question 2, If you are using a layer 3 switch (or multilayer switch) you need to create the Interface vlans (SVI) and execute the command ip routing globally, it will enable the routing service on the switch.
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41860-howto-L3-intervlanrouting.html
Now if your switch is a layer 2, you need a layer 3 device, you can implement router in a stick scheme to implement inter-vlan routing.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
The switch itself can be as a L3 switch.
And I think need enable "ip routing" as well?
so what should be correct config for PBR?
ip routing
interface Vlan10
no shutdown
interface Vlan20
no shutdown
Thanks!
Hi Machi,
Yes, that is correct, but take in consideration you need to create the vlan, assign it to an access port or under a trunk in order to enable the SVI:
vlan 10
int g1/0/1
switchport access vlan 10
switchport mode access
or
int g1/0/1
switchport trunk encapsulation dot1q (some switches have it implicit)
switchport mode trunk.
Now, the default route is used if you are going to know everything through a specific neighbor, take in consideration that if you are going to point to the IP 192.168.3.1 as next hop, you should have a SVI with one IP of the same network segment, it will work like a point to point between routers:
So your config could be:
vlan 30
inter vlan 30
ip address 192.168.3.2 255.255.255.252
no shut
interface g1/0/2
description P2P-TO-DEVICE-X
switchport access vlan 30
I would like to mention tha the multilayer switches has the capability to convert layer 2 switches to layer 3, it can be completed using
interface g1/0/3
no switchport
no shutdown
And example of PBR is:
*Imagine you have 2 routers connected to the switch, a primary router and backup, you could use the PBR to manipulate the traffic to go through the backup router.
set ip next-hop 192.168.3.1
interface vlan10
Hope it is useful
