bridge-group <id> on interface vlan
d.rocco
Hi all,
i configured a bridge-group "29" between interface vlan 1 and the dlsw peer of a cisco 1801 router.
When i put the command on "interface vlan 1", the ip interface vlan don't replay to icmp echo request message; i try to ping the real ip (no standby ip):
________
interface Vlan1
ip address 172.20.10.2 255.255.255.0
standby 1 ip 172.20.10.1
standby 1 priority 255
standby 1 preempt
standby 1 track FastEthernet0 40
bridge-group 29
________
Something know if is this a bug or is a normal situation?
Thank you
Diego
vladrac-ccna
Level 5
Level 5
Just curious, were you able to ping the 172.20.10.1 IP?
I believe you wont be able to route and bridge on the same interface. (unless IRB is configured)
Could you give us the other part of your configuration?
Cant you use a BVI instead?
Vlad
I can ping the virtual ip address and the device routes and bridge on the same interface. Only icmp echo reply on real ip address doesn't work.
I tried with a debug ip packet detail, and i don't see nothing when ping the real ip.
Only if i ping the virtual ip i see the icmp echo request and reply.
I think that is not a configuration problem. Maybe need to add a command on the vlan interface configuration.
however, this is the config:
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no service password-recovery
hostname bbbbb.ccccc
boot-start-marker
boot-end-marker
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip domain lookup
dlsw local-peer peer-id "loopback10"
dlsw remote-peer 0 tcp 10.10.10.10
dlsw remote-peer 0 tcp 10.10.10.11 backup-peer 10.10.10.10 linger 2
dlsw bridge-group 10
interface Loopback10
description "Loopback per DLSW"
ip address 2.2.x.x.255.255.255
interface Loopback99
description "management"
ip address 6.6.x.x.255.255.255
interface FastEthernet0
description "WAN CONNECTION"
ip address 3.3.x.x.255.255.252
speed 10
full-duplex
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
no cdp enable
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
description "LAN Connection"
ip address 172.x.2.x.255.255.0
standby 1 ip 172.20.2.1
standby 1 preempt
bridge-group 10
ip classless
ip route 0.0.0.x.x.0.0 3.3.3.2
no ip http server
no ip http secure-server
control-plane
bridge 10 protocol ieee
line con 0
exec-timeout 5 0
transport preferred none
line aux 0
exec-timeout 5 0
transport input telnet
line vty 0 4
exec-timeout 5 0
line vty 5 15
exec-timeout 5 0
end
for this to work there are three things need to be enabled
1.bridge irb
2.bridge protocol ieee
3.bridge route ip
hope this might help
These don't resolve my issue.
Diego
