Bridge over Cellular interface
akaraduman
Community Member
Hi all,
I'm looking for a way to bridge between a cellular interace and vlan interface on a 881. Is it possible? I failed to find relevant examples. (I also have a dialer interface connected to this cellular interface, though I it can be removed with some configs if not possible like this) My goal is to forward the IP assigned by the ISP(via cellular and/or dialer) directly to the client behind.
Thanks for the ideas in advance
john.laham
Hi, did you ever find a solution to this problem?
I'm facing this exact same problem but with an 819 router connected to a 3G network.
