Bridge RSPAN over GRE (without using ERSPAN)?
packetjockey
The overall goal is to have a method of fine granular sniffing (VACL) and transporting the 'sniffed' traffic over an IP network.
Equipment I have is a cat3550 running c3550-ipservicesk9-mz.122-25.SEE3. I know ERSPAN exists (6500 w/ sup720) but I want this done on a 3550 (this is the challenging part).
I've been attempting to get this done by bridging the rspan vlan over a gre tunnel. I have not had much success with this. GRE tunnel works just fine, rspan vlan is just not being bridged over it.
Just to test the ability of bridging a rspan vlan, I was able to bridge the rspan vlan to another vlan. I took this same concept and attempted to bridge the rspan vlan over a gre tunnel... no luck with this yet.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
ip subnet-zero
vtp mode transparent
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan access-map RSPAN.VACL 10
action forward
match ip address RSPAN.ACL
vlan filter RSPAN.VACL vlan-list 100
vlan 10
name user-vlan
vlan 100
name rspan-vlan
remote-span
vlan 200
name mgmt-vlan
interface Tunnel0
ip address 10.10.10.1 255.255.255.0
tunnel source Vlan200
tunnel destination 10.0.0.2
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0/1
description RSPAN port
switchport trunk native vlan 100
switchport mode dynamic desirable
interface FastEthernet0/15
description Sniffer port
switchport access vlan 200
switchport mode access
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
interface FastEthernet0/31
description User Port
switchport access vlan 10
interface Vlan1
no ip address
shutdown
interface Vlan10
description User VLAN
ip address 192.168.0.1 255.255.255.0
interface Vlan100
description SVI for RSPAN
no ip address
bridge-group 1
interface Vlan200
description external
ip address 10.0.0.1 255.255.255.0
ip classless
ip http server
ip http secure-server
ip access-list extended RSPAN.ACL
permit ip any any
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
monitor session 1 source vlan 10 rx
monitor session 1 destination remote vlan 100 reflector-port Fa0/1
end
Any ideas on how this could be done? Thanks.
amritpatek
Level 6
Level 6
RSPAN source sessions do not copy locally sourced RSPAN VLAN traffic from source trunk ports that carry RSPAN VLANs. RSPAN source sessions do not copy locally sourced RSPAN GRE-encapsulated traffic from source ports.
Each RSPAN source session can have either ports or VLANs as sources, but not both. The RSPAN source session copies traffic from the source ports or source VLANs and switches the traffic over the RSPAN VLAN to the RSPAN destination session. The RSPAN destination session switches the traffic to the destination ports
