alsayed
Level 7
Level 7
Hello!
Network Design and Config
part of the Project Like This:SW1(VLAN100) connected to DS1
SwitchB(Vlan200)Connected to DS2;SW1 HAS Stack Link to SW2.DS1 Has L2 Link to DS2
i will setup 2 DSs and 20 vlans and Run HSRP Between it because the 2 6509 sup 1 doesn't support GLBP so plz examine my Config:
DS1
STP vlan 100 priority 4096
STP vlan 200 priority 8192
DS2
STP vlan 200 priority 4096
STP vlan 100 priority 8192
Now for HSRP
DS1
int vlan 100
ip address 100.x.100.3/24
standby 20 ip 100.200.100.1
standby 20 priority 110
standby 20 preempt
int vlan 200
ip address 100.x.200.3/24
standby 21ip 100.200.200.1
DS2
int vlan 200
standby 21 priority 110
standby 21 preempt
int vlan 100
ip address 100.x.100.2/24
Now:what is ur Greatfull Comments to this Design/config
10xs
Ali
10xs
Edison Ortiz
Very straightforward and I see no problems. Good luck !
Hello Experts!
Ok,let Say we want to move to GLBP Does this Config Works or must config on the DSs stp side Like this:
DS1
Root bridge primary
DS2
Root bridge Secondary
than the GLBP Load Balence across all vlans
any great Coments
Ali
Leave the STP setup as before, since it's layer 2 share. GLBP will load balance at L3.
Hello Again!
what if EACH Switch has 2 direct connection to each Distribution(DS1 & DS2).what would be the config of the STP? Shall i keep it the Same?
10xs
