Bridging Issue
eldin.didic
Hey Guys,
First time I am setting up bridging on my 887. I have done some research and looked at some solutions online although I have not had any luck sorting this one out. I have plugged my wireless router (which is assigning via dhcp) into fe0 assigned to vlan 100. clients on vlan 2 assigned to fe1/3. Not having any luck seeing the internet off vlan 2.
any help would be appreciated!
ip source-route
ip cef
ip dhcp excluded-address 192.168.120.1 192.168.120.20
ip dhcp excluded-address 192.168.254.1 192.168.254.20
ip dhcp pool vlan2-pool
 network 192.168.120.0 255.255.255.0
 dns-server 192.168.120.1 192.168.200.50 192.168.200.51
 default-router 192.168.120.1
 domain-name drh.local
ip dhcp pool vlan100-pool
 network 192.168.254.0 255.255.255.0
 dns-server 8.8.8.8 8.8.4.4
 default-router 192.168.254.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
controller VDSL 0
bridge irb
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 no atm ilmi-keepalive
 bridge-group 100
 pvc 8/35
  encapsulation aal5snap
interface Ethernet0
 no ip address
 shutdown
interface FastEthernet0
 switchport access vlan 100
 no ip address
interface FastEthernet1
 switchport access vlan 2
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 switchport mode trunk
 no ip address
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip address 192.168.121.1 255.255.255.0
interface Vlan2
 description Macquarie LAN
 ip address 192.168.120.1 255.255.255.0
 ip access-group vlan-control in
 ip helper-address 192.168.200.57
 ip nat inside
 ip virtual-reassembly in
interface Vlan100
 description bridging interface
 ip address 192.168.254.1 255.255.255.0
 ip nat outside
 ip tcp adjust-mss 1452
 bridge-group 100
interface BVI100
 no ip address
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list internal-nat-list interface Vlan100 overload
ip route 0.0.0.0 0.0.0.0 Vlan100
ip access-list extended internal-nat-list
 permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended terminal-acl
 permit tcp any any eq 22 log
ip access-list extended vlan-control
 permit ip any any
logging trap debugging
access-list 10 permit 192.168.0.0 0.0.0.255
bridge 100 protocol ieee
bridge 100 route ip
Cheers..
eldin.didic
Some help would be great... :)
You shouldn't assign IP to  VLAN100 interface. The address is allocated to BVI interface.
New output
" interface Vlan100
 no ip address
 ip nat outside
 bridge-group 100
interface BVI100
http://networkingcontrol.wordpress.com/ #CCNP CSCO11962956
Hi quatreduros,
Thanks for the feedback. Unfortunately I still cannot see the internet router from the cisco vlan 2.
EDIT: Do I need to set the BVI's subnet to the subnet that of the other wireless router?
Say my wireless router is 192.168.111.1 and has DHCP running on it, do I set the BVI to 192.168.111.x? Or do I allow the BVI to grab an address from DHCP?
I have used dhcp on the bvi interface. I can now see the internet from the Cisco, but I might have a NAT problem? Still no internet on vlan 2.
Thanks mate!
