Broken VLAN Help!
pinoybot
Frequent Visitor
Frequent Visitor
Hi Cisco Gurus!
I am trying to setup a network via packet tracer, and trying to figure out why one of my network can't communicate. I believe my config is very wrong but I can't really enlighten myself, I greatly need some awesome correction/suggestions....
Basically, I am trying to allow VLAN 3 to be able to browse to 192.168.2.2.
hostname Switch
enable password 7 0822455D0A16
username admin privilege 1 password 7 0822455D0A16
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport trunk allowed vlan 3
switchport mode trunk
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
switchport access vlan 3
switchport mode access
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport trunk native vlan 100
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan3
mac-address 000c.8506.d401
ip address 192.168.3.2 255.255.255.0
interface Vlan50
mac-address 000c.8506.d402
ip address 192.168.3.100 255.255.255.0
line con 0
line vty 0 4
login local
line vty 5 15
login
end
Router#sh run
Building configuration...
Current configuration : 1056 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
interface GigabitEthernet0/0/0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
ip address 10.10.1.2 255.255.255.252
ip nat outside
clock rate 64000
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 192.168.1.0
network 192.168.3.0
no auto-summary
ip nat inside source list 1 interface Serial0/1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1/0
ip flow-export version 9
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
Current configuration : 855 bytes
version 15.4
hostname Router
no ip cef
no ipv6 cef
ip domain-name cisco.com
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 10.10.1.1 255.255.255.252
ip nat outside
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source static 192.168.2.2 10.10.1.1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router con0 is now available
Press RETURN to get started.
Router>en
Router#sh run
version 15.4
hostname Router
no ip cef
no ipv6 cef
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip nat outside
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
I'd greatly appreciate any answers, thank you so much in advance.
Georg Pauwen
the problem is most likely to be with inter-Vlan routing, as you don't have a subinterface configured for Vlan 3 on your router.
Best to post the .pkt file here so we can check your configs...
9 Replies 9
Georg Pauwen
Hi Georg,
You're correct I should have attached it, and I will once I get back home. I posted the 2 router configs in my post last night, there's just a delay before it comes up. I will attach it here as a txt file for now.
There are a few things that need to be verified, that is why it is easier to get the project file. The trunk link to your router has specified Vlan 100 as the native VLAN, is there a specific reason for that ?
I will definitely upload the pkt file later. I used vlan 100 thinking I have to since I'm using 100 as my native? I also have a question with my routing, I used a static at first but I added the RIP thinking that could be the reason why I can communicate to the web server.
Is this a lab ?
Either way, using RIP is fine, you just need a way to get from router to router...
It's kind of a lab since I'm replicating a network I've seen. But since I'm using a VLAN, should I be using a sub interface on the router?
Router 0
duplex auto
speed auto
I'll set it to:
interface GigabitEthernet0/0/1.3
encapsulation dot1Q 3
I'll attach the pkt once I get home.
Looks like subinterface is the key. It worked now. I just realized that's how it works.
indeed that is what you need. The concept is called 'Router-on-a-stick'...
Awesome Thanks! I actually thought it's just for cheap network setup, didn't realize that's the concept purposedly for vlans.
