Can a layer 2 port channel load balance hash mode use src-dst-port ?
luverofpeanuts
I have two servers connected to a pair of Nexus 7K (peers).  Each server is connected to a 4 port LACP port channel (vPC, I think).   The switch and all modules are using the default load balance hash mode.... i.e..
show port-channel load-balance
Non-IP: src-dst mac
IP: src-dst ip rotate 0
Each of my servers (on the same tcp subnet), when using multiple tcp connections and ports, can utilize all 4 ports sending flows.  However, the receiver of these flows is only receiving on two of the 4 ports.  Would switching the port channel load balance mode to src-dst-port allow the sending and receiving tcp port numbers to included in the hash, and thus have the switch send flows to my receiver on all 4 links?
It seems like it would, but I've been led to believe that since the traffic is all layer 2, it will not.  I'm not sure if I should believe that.
Thanks for your thoughts.
dbeattie
Yes, a L2 port-channel can use L3/L4 fields as part of the load balancing algorithm for IP traffic.
Hope this helps.
Dave
dbeattie
Hope this helps.
Dave
Thank you!   It would be nice if there was Cisco documentation I could point to that made it clear.
