brom issue
ihammadali
Hii ,
Is any one tell me that how to recover the switch from brom mode . If there is good and experienced solution is available then let me know .
Thanks ,
7 Replies 7
Julio E. Moisa
If you have still contract, a case should be opened with the Cisco TAC.
https://supportforums.cisco.com/discussion/12251826/brom-boot-2960xr-switch
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Dear Julio ,
my issue is still persist and i want urgent solution on it .
dear Julio ,
I have checked the link which you are mentioned above but on that no solution is available .I believe that there is a solution  available to recover the switch from brom but i am not able to get yet .
Unfortunately is the only information I have found. Could you please share the complete error message. Apparently it is a hardware failure, you could reach the Cisco TAC in order to open a case
https://supportforums.cisco.com/discussion/12483316/catalyst-2960-x-not-booting-showing-brom-prompt
Dear Julio,
I am very thanks full to you that sharing your input .....
It was a pleasure my friend.
Leo Laohoo
Raise a TAC Case and get the appliance RMA-ed.
