Showing results forĀ
Search instead forĀ
Did you mean:Ā
bypassing the router and connecting to another lan
OneCiscoGuy
i have a 2600 router, and the config is.
- ether0 = 192.168.1.1
- ether1 = 192.168.2.1
these are  two seperate networks.
what i will like to do is to an configure access-list that will have the clients in the 192.168.2.0 network to be able to access only one server in the 192.168.1.0 network (the server will be 192.168.1.8 a proxy server). and then no access to other clients in this 192.168.1 network.
help please....
Amit Singh
This should be like this.
access-list 101 permit ip 192.168.2.0 0.0.0.255 host 192.168.1.8
access-list 101 deny ip any any
There is an explicit deny at the end of the access-list so you are good even if you dont configure the second ACE.
Then attach it to the Ether1 interface using the command :
Int ether1
ip access-group 101 in
You can change the ACl a bit if you want to attach it to the Eth0 interface. Typically we attach ACL as close as to the source interface of the traffic.
HTH,
-amit singh
