C1841 DHCP not working but same config worked at Packet tracer
version 12.4
IOS : IPBASE-M 124.15T12
hostname FIN
boot-start-marker
boot-end-marker
enable secret 5 $1$.kn2$MdOTV7sAQTm.sbLu36HP0.
enable password admin
no aaa new-model
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp pool FIN
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   dns-server 8.8.8.8
ip address-pool dhcp-pool
archive
 log config
  hidekeys
interface FastEthernet0/0
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.5.2 255.255.255.0
 no ip route-cache
 speed auto
 half-duplex
 no mop enabled
ip forward-protocol nd
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 password admin
 login
scheduler allocate 20000 1000
end
2 Accepted Solutions
You are excluding the entire address space !!! Exclude just the 5.2 address...
That means:
--> no ip dhcp excluded-address 192.168.5.1 192.168.5.254
--> ip dhcp excluded-address 192.168.5.2
16 Replies 16
make the changes marked in bold:
version 12.4
hostname FIN
boot-start-marker
boot-end-marker
no aaa new-model
--> ip routing
no ip cef
ip dhcp pool FIN
dns-server 8.8.8.8
archive
log config
hidekeys
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
ip address 192.168.5.1 255.255.255.0
no ip route-cache
speed auto
half-duplex
no mop enabled
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password admin
login
end
Thank you Georg Pauwen!
Still the issue not solved
ip routing is not working.
Post the full running config again, with the changes you have made...
1841#conf t
1841(config)#ip routing
is not working ?
I made the change.
But dhcp not pooling ip to pc.
When i try to 1841#confi t # ip routing
ip routing is not working .
version 12.4
hostname FIN
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool FIN
   dns-server 8.8.8.8
ip address-pool local
archive
 log config
  hidekeys
 no ip address
 shutdown
 duplex auto
 speed auto
 duplex auto
 speed auto
 no mop enabled
ip route profile
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 password admin
 login
end
How is your PC connected to the router ? Is there a switch in between ?
No just direct connected to the pc on  port fa0/1
Since you are using an older IOS version, make sure 'service dhcp' is enabled:
1841(config)#service dhcp
Since we are used just for static ip it was worked normally. We need dhcp.
service dhcp is enabled
Would you post the output of show interface?
What type of cable are you using to connect the PC to the router? If the PC is directly connected to router it should be a cross over cable and not a straight through cable.
Rick
Rick
We using cross over cable.
See show inter?
show run
DHCP_OK#show running-config
Building configuration...
Current configuration : 896 bytes
version 12.4
hostname DHCP_OK
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
--More--  ip dhcp pool JACK
--More--   network 192.168.5.0 255.255.255.0
--More--   default-router 192.168.5.2
--More--   dns-server 8.8.8.8
--More--  !
--More--  !
--More--  multilink bundle-name authenticated
--More--  !
--More--  !
--More--  archive
--More--   log config
--More--   hidekeys
--More--  !
--More--  !
--More--  !
--More--  !
--More--  !
--More--  interface FastEthernet0/0
--More--   no ip address
--More--   shutdown
--More--   duplex auto
--More--   speed auto
--More--  !
--More--  interface FastEthernet0/1
--More--   ip address 192.168.5.2 255.255.255.0
--More--   speed 100
--More--   full-duplex
--More--   no mop enabled
--More--  !
--More--  ip forward-protocol nd
--More--  !
--More--  !
--More--  ip http server
--More--  !
--More--  !
--More--  !
--More--  control-plane
--More--  !
--More--  !
--More--  line con 0
--More--  line aux 0
--More--  line vty 0 4
--More--   password admin
--More--   login
--More--  !
--More--  scheduler allocate 20000 1000
--More--  end
--More--
DHCP_OK#
DHCP_OK#show interfaces fas 0/1
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is fcfb.fbbd.65ef (bia fcfb.fbbd.65ef)
Internet address is 192.168.5.2/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:18, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
578 packets input, 78115 bytes
Received 382 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
282 packets output, 28726 bytes, 0 underruns
0 output errors, 0 collisions, 13 interface resets
--More--   0 unknown protocol drops
--More--   0 babbles, 0 late collision, 0 deferred
--More--   0 lost carrier, 0 no carrier
--More--   0 output buffer failures, 0 output buffers swapped out
That means:
Good catch by Georg. +5
It is good that the interface shows as up/up. I hope that fixing the DHCP excluded addresses will result in the PC receiving an IP address and working. If not then please post the output of show arp.
Rick
Rick
Thank you Its worked.
