C1841 DHCP not working but same config worked at Packet tracer
version 12.4
IOS : IPBASE-M 124.15T12
hostname FIN
boot-start-marker
boot-end-marker
enable secret 5 $1$.kn2$MdOTV7sAQTm.sbLu36HP0.
enable password admin
no aaa new-model
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp pool FIN
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   dns-server 8.8.8.8
ip address-pool dhcp-pool
archive
 log config
  hidekeys
interface FastEthernet0/0
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.5.2 255.255.255.0
 no ip route-cache
 speed auto
 half-duplex
 no mop enabled
ip forward-protocol nd
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 password admin
 login
scheduler allocate 20000 1000
end
16 Replies 16
Thank you for confirming that the suggestion by Georg did solve your problem. That is good to know. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information.
Rick
Rick
Tinei
Are you connecting your pc direct to the router or you have switch between pc and router. If you have a switch connected between PC and router then you need configure the link as a trunk link so that it can pass VLAN traffic. You will then need to configure the switch with a VLAN for the particular IP address that you need to work.
