C1841-starting with rommon prompt, boot:cannot open flash
My C1841 startting with rommon prompt
when i tried to boot using the following command rommon 2 >boot flash:
i got the following error messages:
boot:cannot determine first executable file name on device flash.
VJ,
7 Replies 7
Leo Laohoo
What do you get when you enter the command "dir flash:"?
Hi leo,
rommon 18 >dir flash:
dir: cannot open device "flash:"
VJ.
It's either
1.  the flash drive or the flash card is faulty;
2.  someone inserted the wrong CF; or
3.  someone deleted the CF
The quickest way is to eject the CF and insert it into a multi-card reader.  If you have a windows client, format the CF using FAT16.  Once format is complete copy the IOS from your client to the CF and re-insert the CF back to the router.
Otherwise, use this process:
How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMMON Command
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Thanks for the details leo.
i have a USB slot in my C1841,
is it possible to copy the bin files to usb and install via usb ?.
Vijay.
Not possible unless you have bootstrap version 12.4(13r)T6 and later.
Hi Leo,
i have checked the 64mb compact flash in the card reader
compact flash not reading, it seems compact flash is faulty,
Non cisco brand CF's will work in C1841 ?
please suggest some CF brands that works with C1841,
Vijay,
1.  Maximum size is 2Gb.
2.  Not all brands/manufacturer supported.  Try one and if it works, buy it.
3.  If it works, format with FAT16 on a Windows client, drop the file into the CF and boot the CF.
