c2821 Maximum Number of Vlans encap. dot1q
How many Vlans encapsulation dot1q does support an c2821 with 2 Gigabit Ethernet interfaces?
Thanks.
Giuseppe Larosa
Hello Mariano,
in a router each Vlan subif takes a row in the IDB = interface descriptor block.
the total of physical and logical interfaces on your router cannot be higher then the IDB size.
This number is dependent on platform and IOS version.
on a c2821 the IDB can be 512
I didn't find the number so you should be able to implement several subinterfaces on your router.
2821
900
see
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml#idb_limits
I shouldn't go behind 20 subinterfaces per GE there are other factors to be considered like the size of the NIC MAC packet filter.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mariano,
2821
900
see
Hope to help
Giuseppe
Giuseppe, thank you very much. It is that i was needed.
Mariano.
