c2960s ether-channel limit question
I have WS-C2960S-F48TS-L switch with lanbase license:
#sh license
Index 1 Feature: lanlite
        Period left: 0  minute  0  second
Index 2 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
unfortunatelly I can't create more than 6 ether-channels:
(config)#int port-channel 7
% Invalid input detected at '^' marker.
(config-if)#channel-group 7
according to the documentation lanbase license should allowe me to create up to 48 ether-channels,
Could you tell what can be the issue with it?
Pawel
Steve Fuller
Level 9
Level 9
The Catalyst 2960S only supports six port-channels, and when looking at the context sensitive help on the switch the port-channel interface number must be between 1 and 6.
This is documented in the EtherChannel Configuration Guidelines in the Configuring EtherChannels and Link-State Tracking section of the software configuration guide.
Follow these guidelines to avoid configuration problems:
  • Do not try to configure more than 6 EtherChannels on the switch stack.
Do you have the link showing support for 48 port-channels?
Steve Fuller
Level 9
Level 9
devils_advocate
Level 7
Level 7
I believe the 2960 series has a maximum of 6.
What documentation did you find which states it can have a maximum of 48?
Sorry my bad, I missed information in the parentheses in the
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps6406/feature_set_comparison_2960-s.pdf
page 13.
Unfortunately you're right and there is only 6 ether-channels supported.
Thanks for the answers.
-Pawel
In the event that you are running a 2960s in a stack with another, would you be given 12 Port channels?
