c3560-24PS-s Switch with IPBase IOS
Muhammad1Ali
Dear Friends,
I have two switches of cisco c3560-24PS-s with IPbase ios installed. I need the routing OSPF and RIPv2 for my network.
But these switches not support OSPF while they can support RIPV2.
Can i upgrade this switch to any IPservices IOS that work ospf for me?
I tried one, it was showing all the thing about ospf: Like
(config)# Router ospf 100 was supporting but it was not working , not making the adjecency.
Please guide me and help me in this regards
Ali Khan
Leo Laohoo
Yes.
Please send the following outputs,(ip base)
sh ver
sh license summary
sh boot
1) Version= C3560-IPSERVICESK9-M), Version 12.2(55)SE7,
2) show boot
  BOOT path-list      : flash:/c3560-ipservicesk9-mz.122-55.SE7.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   524288
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
my provider updated it to Ipservices and ospf shows everything but not working
3) Show license summary
  This command is not recognized
If you switch is running IP Services then it may be your config.
Can you post the OPSF config from the switch and the other switches/routers that are running OSPF ?
What does "sh ip opsf neigh" show ?
Jon
