C3650 with WLC upgrade questions
toskie9999
Hi guys just a quick question what do I need to check on the WLC part of the switch before upgrade since the switch upgrade it self is pretty straightforward but since the switch has AP licenses installed I am worried those might be lost after upgrade. Is there anything I need to check/backup before commencing with upgrade.
by the way I will be upgrading from Release 3.7.2E to Release 3.7.5E
Reza Sharifi
Upgrading the software should not affect the switches main license or the AP license.
Reza Sharifi
