Showing results forĀ
Search instead forĀ
Did you mean:Ā
C3750X configure etherchannel with netapp
khuyenhoang
Hello Cisco experts,
I have configured Cisco C3750X-48TS etherchannel with netapp FAS2240 configured  static multi_mode .
interface Port-channel1
description FAS2240
flowcontrol receive on
spanning-tree guard loop
interface GigabitEthernet1/0/37
no cdp enable
channel-group 1 mode on
interface GigabitEthernet1/0/38
no cdp enable
After finish i make a test by transfering bulk data between host to Netapp 2240
and using command :
>ifgrp stat ifgrp01 on netapp. Here is a result from Netapp 2240.
fas2240a*> ifgrp stat ifgro   p01
Interface group(trunk) ifgrp01
        e0a                 e0c
  Pkts In   Pkts Out  Pkts In   Pkts Out
  1458m     738m      1574m     537m
  37        0         24257     19488
  26        0         29780     24335
  21        0         27625     21592
  26        0         22600     18088
  36        0         26997     21787
  29        0         25093     20106
  23        0         24649     20462
  20        0         27884     22852
  33        0         23202     18472
  24        0         27121     21215
  23        0         23637     18001
  21        0         23001     17625
  24        0         22984     17725
  32        0         22341     17352
  21        0         21960     16922
  23        0         20662     16444
  32        0         18180     13994
  25        0         15177     11262
  27        0         13175     9078
  18        0         13819     9482
  31        0         14433     9975
the interface e0a seem doesn't work only e0c has data load on it.
Could you please advice me how to correct my trouble!
Thanks so much!
Jon Marshall
Different switches support different load balancing methods eg. src/dst mac, src/dst IP, src/dst port but the one thing common to etherchannel load balancing is that a single conversation between two devices will always be sent down one specific link. This is what you are seeing ie. at one end you have the netapp device and the other the host. This is a single conversation so it will always use the same physical port in the etherchannel group.
Now lets say you had another host and started a conversation between that host and the netapp device. This is now seen as a different conversation and may well be allocated to the other link.
So what you are seeing is normal behaviour. If you actually needed more than 1Gbps throughput between a specific host and the the netapp device etherchannel is not the solution ie. you would need faster interfaces in the devices.
Jon
