C3750X stack power problem
gnijs
Level 8
Level 8
Hello all,
Just arrived in the lab: 2x C3750X but i just can't get stack-power to work.
First,
  These switches are non-PoE: 2x WS-C3750X-48T-S
  Can someone confirm that stack power is going to work for these switches ? I am not concerned about powering edge devices, just
   the switch itself. For example: one switch has dual power supplies, the second one not. If the power fails of the last one, one of the dual supplies
   of the first switch, should power the second switch in the stack.
Second,
I have connected my powerstack cables, but all ports remain SHUT no matter what i try:
Do i need to unshut the ports ? Or is this automatically ?
Switch# sh stack-power
Power stack name: Powerstack-2
    Stack mode: Power sharing
    Stack topology: Standalone
    Switch 2:
        Power budget: 223
        Low port priority value: 22
        High port priority value: 5
        Switch priority value: 4
        Port 1 status: Shut
        Port 2 status: Shut
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: 0000.0000.0000
Power stack name: TEST
    Switch 1:
        Power budget: 223
        Low port priority value: 20
        High port priority value: 13
        Port 1 status: Shut
        Port 2 status: Shut
Third,
I am running version 12.2(55)SE1
And i am running ipbase software:
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
Fourth,
Do i need a full-loop power stack configuration ? Otherwise: between two switches, do i need to connect two powerstack cables, or is a single
powerstack cable also enough to make it work ?
Am i missing something fundamental here ?
regards,
Geert
Switch#  sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
TEMPERATURE is OK
Temperature Value: 27 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT15060STG  OK              Good     Good     350/0
1B                                   No Input Power  Bad      N/A      235/0
2A  C3KX-PWR-350WAC     LIT15060STB  OK              Good     Good     350/0
2B  C3KX-PWR-350WAC     LIT15060STU  OK              Good     Good     350/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
gnijs
Level 8
Level 8
Aaaarchchhhh....
Found it myself:
conf t
stack-power switch 1
  no standalone
stack-power switch 2
  no standalone
