ā06-13-2017 10:09 AM - edited ā03-08-2019 10:57 AM
In the process of upgrading several C3750X switches from 122-55.SE5 IOS to 150-2.SE10a. which are uplinked to C3850-24S SFP fiber Interfaces.
The C3850 IOS-XE is 03.06.03.E.152-2.E3
In almost all of the upgrades, which are successful on the C3750 switch, it has been necessary to reset(shut/no shut) the 3850 interface in order to restore connectivity to the 3750 switch. Has anyone experienced this issue/have any suggestions to enable the connection with out manual intervention?
Solved! Go to Solution.
ā06-13-2017 03:16 PM
Check the Release Notes of the 3850, particularly the 3.6.5 or 3.6.6. I've seen several identified bugs which involves 3750X fibre interfaces behaving like this after a reboot.
ā06-13-2017 10:59 AM
Nop, have you verified if the ports got any err-disable error?
ā06-13-2017 11:26 AM
Hi Julio,
No the ports are not in err-disable state, they are in not connected state and reset brings the interface back up
