C3850 port drops
NetwkP
I am using a qnx computer with a Broadcom fiber card (1000 baseSX full duplex) connected to a C3850. The light on the switch port only flashes for a couple of minutes after rebooting the qnx computer, after that it stays off. I tried two ports and I have the same result, the port configuration and status are showing below. I know that the Broadcom fiber card is working because I used a Fiber optical media converter and connected to another computer and the link is up.
Broadcom <- fiber-> media converter <-Ethernet-> 2nd computer.
I also used the media converter to connect the second computer to the switch and the link is up.
2nd compuer <-Ethernet-> media converter <-Fiber-> C3850
The qnx computer also has a Ethernet card which I connected to the media converter into the switch and the link is up.
Qnx computer <-Ethernet-> media converter <-Fiber-> C3850.
Only when the there is a connection from the Broadcom to the switch the communication drops.
Does any body know what can be the root of the issue?
TenGigabitEthernet1/0/3 is down, line protocol is down (notconnect)
 switchport mode access
 spanning-tree portfast
  Hardware is Ten Gigabit Ethernet, address is cc98.91d6.cf03 (bia cc98.91d6.cf03)
  Description: Element Manager A
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
TenGigabitEthernet1/0/4 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is cc98.91d6.cf04 (bia cc98.91d6.cf04)
  Description: Element Manager B
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
     0 packets input, 3136 bytes, 0 no buffer
     0 watchdog, 0 multicast, 49 pause input
     10104 packets output, 9766160 bytes, 0 underruns
7 Replies 7
Leo Laohoo
Check the fibre optic cable. Maybe is broken?
Leo, I used the same Fiber Cable that I was using to connect to the Media Converter. So fiber connection is not the problem.
Post the complete output to the following commands:
1. sh version;
2. sh idprom interface Ten 1/0/3;
3. sh idprom interface Ten 1/0/4
#sh version:
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.07.04E RELEASE SOFTWARE (fc1)
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
cisco WS-C3850-24XS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW2129C163
2 Virtual Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
2 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
255037K bytes of Crash Files at crashinfo:.
3435916K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Switch Ports Model              SW Version        SW Image              Mode
*    1 34    WS-C3850-24XS      03.07.04E         cat3k_caa-universalk9 INSTALL
#sh idprom int Ten 1/0/3
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x01 0x00 0x00 0x00 0x00
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO
Vendor Part Number    :   SFBR-5716PTZ-CS1
Vendor Revision       :   0x30 0x30 0x31 0x20
Vendor Serial Number  :   AGV2101SMDY
Other Information
Chk for link status   : 00
Flow control Receive  : Off
Flow control Send     : Off
Administrative Speed  : 1000
Administrative Duplex : full
Operational Speed     : 1000
Operational Duplex    : full
#sh idprom int Ten 1/0/4
Identifier            :   0x03
Connector             :   0x07
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO
Vendor Serial Number  :   AGV2117SPV9
Other Information
Try replacing one of these SFP with something that doesn't have a serial number that starts with an "A".
I'm trying to find a bug I read about issue(s) about SFPs made by Avago.
Reza Sharifi
Can you try swapping the fiber strands on one side of the connection and test again?
I tried that, the light on the Broadcom Fiber card is normally on when I have it in the right position. If I swap the fibers on any of the two sides, it would turn off.
