C3850 QoS verification
vladakoci
I am implementing QoS on C3850 and trying to find a good document that would describe commands that I would need to verify if my implementation is successful.
1.
Is there any way how I could see per port class statistics ?
Something like this
show  policy-map int g1/0/15
shows aggregates - classification counter      aggregates all packets belonging to the same class of the same policy      which attach to different interfaces.
2.
Is there any command that I could use to see what queues my classes use, like in the one below I can see I am using three queues, but have no clue how I could see what classes use them. Reading some documents I  guess two of them might be priority queues.
show platform qos que stats g 1/0/15
DATA Port:11 Enqueue Counters
Queue Buffers Enqueue-TH0 Enqueue-TH1 Enqueue-TH2
    0       0           0           0    64440167
    1       0           0           0    13709990
    2       0           0           0  1912882424
    3       0           0           0           0
    4       0           0           0           0
    5       0           0           0           0
    6       0           0           0           0
    7       0           0           0           0
3.
show platform qos dscp-cos count g 1/0/15
Ingress DSCP0 787315        0
Ingress DSCP1 0             0
Ingress DSCP2 0             0
Ingress DSCP3 0             0
Ingress DSCP4 1             0
What does the first column show - I guess the number of packets/frames that correspond to Ingress/Egress DSCP/COS ? What is the second column about ? I have zeroes everywhere.
Thank you.
Vlad
0 Replies 0
