08-04-2015 03:59 AM - edited 03-08-2019 01:13 AM
We cannot run C3KX-NM-10G at 1G mode for all 4 ports.
3750x recognize(can work) only with two 1G GLC-LH-SM SFP modules in the same time, what ever port are used G1 /G2 or G3/G4.
08-04-2015 01:13 PM
These are the combinations you should be able to use
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/net_mod_note.html
08-04-2015 01:16 PM
C3KX-NM-10G (Figure 2) | The module has four slots. Two slots support only 1-Gigabit SFP modules. Two slots support either 1-Gigabit SFP or 10-Gigabit SFP+ modules. Note The four slots are grouped as two pairs, with each pair consisting of one SFP slot and one SFP+ slot. Each pair supports either two 1-Gigabit SFP modules or one 10-Gigabit SFP+ module. A 10-Gigabit SFP+ module cannot operate at the same time as the corresponding 1-Gigabit SFP module in the pair. |
08-04-2015 10:32 PM
Hello Mark,
The Cisco guide was the first thing I did, but there is no an answer why module recognize only first two inserted sfp what ever port are used.
08-05-2015 12:36 AM
Sorry i dont get what you mean its only supposed to support 2x1gb thats the way its designed , if you want a module that supports 4x1gb you need to use the 1g C3KX-NM-1G
08-05-2015 12:41 AM
So, C3KX-NM-10G support only two 1G SFP connected same time per 4 ports?
But, what does it mean:
Supported combinations of SFP and SFP+ modules:
•Slots 1, 2, 3, and 4 with 1-Gigabit SFP modules
and
The four slots are grouped as two pairs.Each pair supports either two 1-Gigabit SFP modules or one 10-Gigabit SFP+ module.
08-05-2015 12:54 AM
Yes i need to test it to be sure the doc is not that clear as it also says
08-05-2015 10:15 PM
Official Cisco integrator confirmed the possibility of using all four slots with 1G modules in the same time.
