C4948E-S - Really slow performance IP routing
gareth_r52
I have a C4948E-S switch, on 12.2(54)SG1.
I have two VLANs (5,10)...
192.168.5.0/24
192.168.10/24
I've enabled IP routing, ip cef is on by default, also enabled ip multicast routing. With both machines HOST A connected on VLAN 5 and HOST B pointing to the relevent gateway (switches VLAN interface IP)... I have perfect connectivity.
However, when using iperf, if I connect both hosts to the same VLAN I get:
987 MBytes   857 Mbits/sec
However, if they are on seperate VLANs I get the following:
118 MBytes  98.9 Mbits/sec
I also have a 3560X and this performs fine, so there is something wrong with the 4948E... can anyone advise if they have seen this before and what I should do?
Here are some interface diags:
Vlan5 is up, line protocol is up
  Hardware is Ethernet SVI, address is
  Description: VLAN FIVE
  Internet address is 192.168.5.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  IPv6 L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  IPv6 L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
     820 packets input, 75521 bytes, 0 no buffer
     Received 1211 broadcasts (122 IP multicasts)
     9512 packets output, 1017536 bytes, 0 underruns
     0 output errors, 0 interface resets
Many thanks.
0 Replies 0
