C500 Switch
lalit0005
Community Member
I am facing some problem with the C500 switch.Switch port is hang imultaneously in between 3 to 4 hour.And after restart the switch its working some time and
again goes down.
I have system massages in that it shows me caused by MAC address 0201.0000.0000. on port fastethernet14.i didn?t understand where the exact problem.
htarra
Level 9
Level 9
I think when you discover a device in the Discover Devices dialog box, the application sometimes displays the following dialog boxes as prompts:
Security Certificate
VPN Peer IP Address
Device Credentials
Sometimes, these dialog boxes disappear behind the Discover Devices dialog box, and the device discovery appears to hang.
Jagdeep Gambhir
Level 11
Level 11
Make sure that you have 12.2.25 SEG running on the box , set up the right switch port role.
~JG
Box running on 12.2.25 SEG.and port role is Desktop.Still we face the same problem.I also check by replacing the switch but still problem is not solved.
