02-01-2008 01:59 AM - edited 03-05-2019 08:52 PM
My question is :
I ve two C6506 ( not E-chassis ) can I replace my two Sup720-3B per chassis by one S720-10G-3C ( per chassis ) or use one 67xx per chassis , S720-3B remaining ?
02-01-2008 03:30 AM
Yes you can sue the S720-10G-3C in a C6506 chassis. The only chassis not supported are the 6509-NEB and the 6503 Non-E chassis.
See attached link for more details:
You can also use your second option of using the 67xx card with a Sup720-3B.
Jon
02-01-2008 05:49 AM
Thanks You very much Jon.
Best Regards
Francois
