C6807 password recovery doesn't work
jonathan.lacaze
The password recovery procedure doesn't work for me on C6807.
The confreg 0x2142 and reset in rommon work but after the reboot I still have the username asked.
You'll find in attach the terminal log.
@jonathan.lacaze wrote:
There is two SUP2T-10G
I reviewed the original boot-up process and I can see that the line card is booting up as "Standby".
The password-recovery process will only work if the line card works stand alone.
Tell me more about this line card:  Was the line card sourced from a "used" seller?  And did the owner disable password-recovery feature?
9 Replies 9
Mark Malone
Hi has , no service password recovery been enabled in the global config ?
even though this is 720 sup could be something similar happening and bypassing the password recovery if its not setup , you could try this method
https://community.cisco.com/t5/switching/password-recovery-confreg-0x2142-doesn-t-work/td-p/702250
I already saw and test this solution but it doesn't work for me.
During boot I never have the following log message : 00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor.
I don't see the RP gains control. As you can see in my terminal log.
In attach you will find my terminal log for a "normal boot".
Finally, we found the old password.
However, I tried password-recovery with two line card so I think that you are right.
Thanks for your Help.
I don't know.
Can I check this ?
Leo Laohoo
Could you try the username/password of "Cisco/Cisco"?
It doesn't work :
Username: Cisco
Password:
% Authentication failed
