c9200 mac adress persistence with MAB and VOIP
renard sebast
I have switch c9200 with MAB and vlan assignment, on the user ports it has IP phones and the PCs are connected to these phone.
When I disconnect a PC, its MAC address still appears on mac adresse table for that port.
Of course if i shutdown a port or if i disconnect the phone, all mac adress are clear for that port.
How to make mac address automatically refresh when I disconnect a PC ?
interface GigabitEthernet1/0/1
switchport mode access
switchport voice vlan 999
authentication host-mode multi-auth
authentication port-control auto
authentication periodic
authentication timer reauthenticate 7200
authentication violation protect
mab
dot1x pae authenticator
dot1x timeout quiet-period 2
dot1x timeout tx-period 3
spanning-tree portfast
Thank you in advance for your help
6 Replies 6
this feature is support in CDP enhancement
which make IP phone send CDP announce the SW about the down of port PC connect to
I think 9300 is new and support this feature but the ip phone if not support then you need
reauth which make SW ask reauth the PC and PC not reply and SW remove the MAC from table.
NOTE:- check why client OS not send logoff to SW, this also help in this case
as far as I recall, MAB is often used in conjunction with port security and sticky MAC addresses. Is that an option for you ?
You can set the timeout value to a lower value:
interface GigabitEthernet1/0/1 # Replace with the actual interface of the switch
switchport port-security maximum 2 # Set the maximum number of secure MAC addresses
switchport port-security aging time 2 # Set the MAC address aging time in minutes
switchport port-security violation restrict # Set the violation action (restrict, protect, shutdown)
switchport port-security mac-address sticky
renard sebast
Thanks for the replies
My IP phones are not Cisco phones, It's mittel phone and they use lldp.
I have a similar configuration with Dell switches and the same phones it works without problem with lldp
I try Georg's solution as soon as I can
Can yoh check tlv lldp use in other vendor and one use by SW
There is tlv that do same as cdp enhancement.
MHM
renard sebast
Hello thank for reply ,
Sorry I'm a bit lost with the lldp protocol
On my dell switch n2200 i have :
show lldp interface gigabitethernet 1/0/1
LLDP Interface Configuration
Interface Link Transmit Receive Notify TLVs
Gi1/0/1 Up Enabled Enabled Disabled 0,1
TLV Codes: 0- Port Description, 1- System Name, 2- System Description
3- System Capabilities, 4- Port VLAN, 5- Management Address
On my C9200
show lldp interface gigabitEthernet 1/0/1
GigabitEthernet1/0/1:
Tx: enabled
Rx: enabled
Tx state: IDLE
Rx state: WAIT FOR FRAME
I'm not sure I have the right information on my Cisco switch. I don't see any active tlv
But if I understand correctly I had to turn on the tlv "Port Description" and "System Name" in conf t
Can you add these below tlv under ONE port  (not in global mode) and check
TLV Codes:
1- System Name,
4- Port VLAN,
I check lldp but I couldn't find which tlv use to inform SW the PC port is disconnected
MHM
