C9200L-24T-4G-A Heat dissipation BTU/hr
plyj
Attempted the power calculator tool but could not find the specified product. The closest product uses a 600W power supply which is different from the 125W power supply used by the specific switch.
Can anyone help with this please?
acampbell
Your C9200L-24T-4G-A is a fixed uplink mod switch.
It only takes a PWR-C5-125WAC PSU as it does not support POE.
The BTU/Hour = 426.5
All this info is from the Data Sheet
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html#Specifications
Hope this helps
Regards, Alex. Please rate useful posts.
