C9200L-48P-4x DATA stack an not power
Clem58
Level 3
Level 3
Could you please confirm the C9200L-48P-4, like other C9200 or C9200L can do only DATA stack (StackWise) with C9200L-STACK-KIT, and this not possible to have power stack ?
Do you have any Cisco document that specifically mentions that ? I cannot find.
Many thanks by advance for your help.
5 Replies 5
M02@rt37
Hello @Clem58
Documentation talk about data stack _ no power stack fort that model.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/217684-verify-and-troubleshoot-stackwise-on-cat.html
Best regards
pieterh
from own experience i can tell it does not support stack-power
if you need document to "prove" this look at the
hardware installation guide and achitecture whitepaper, that  do not mention anything about stack-power
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/hardware/install/b-c9200-hig/installing_the_switch.html
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-architecture-cte-en.html
if it did support, it would definively be mentioned in those documents
Jens Albrecht
Hello @Clem58,
you will not find Cisco documentation talking about features that are NOT implemented.
So if you search for a specific feature and cannot find it in the documentation for a platform, then this typically means that this feature does not exit on that platform.
You cannot find any information about power stacking on the Catalyst 9200L platform?
You guess it, this feature is not supported on this platform.
HTH!
julian.bendix
Level 7
Level 7
Can confirm too, it doesn't support it.
lpenadav
Hello Clem58,
StackPower is not supported on Catalyst 9200 or Catalyst 9300L series switches
You can refer to the document below for more information on configuring and troubleshooting StackPower.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-switch/217759-configure-and-troubleshoot-stackpower-an.html
