06-07-2021 12:40 PM - edited 06-07-2021 12:41 PM
We have a new C9300-48T(Stack of 5).
I have configured SSH but not able to login using ssh...
When I am trying to SSH, it's showing Connection established and getting stuck, no login propmpt popping up
You can see the above image, nothing is happening after this
Options I tried:
1. zeroize the key and regenerated (2048 bit)
2. deleted username, password and recreated
3. deleted enable secret and recreated
Config:
line con 0
no password
privilege level 15
exec-timeout 15 0
line vty 0 4
password xxxxx
exec-timeout 15 0
privilege level 15
transport input telnet ssh
enable secret xxxxxx
line vty 5 15
no password
exec-timeout 15 0
privilege level 15
Tried with below config as well:
line vty 0 4
password xxxxx
login local
line vty 5 15
password xxxxx
login local
None of these worked
Please help
06-07-2021 12:55 PM
Can you post show run full config to look rest of the config or try below simple config to test :
ip domain-name cisco.com
ip ssh version 2
crypto key generate rsa general-keys modulus 2048
username bbalaji privilege 15 password mypasstest
line vty 0 15
transport input ssh
privilege level 15
login local
06-07-2021 01:16 PM - edited 08-10-2021 07:34 AM
Removing config
06-07-2021 01:28 PM
One more thing wanted to let you know that, we are replacing old core switch(45k) with this one(C-9300), and haven't configured it yet, so we just wanted internet connection into this new switch so that we can activate smart license.
So I have attached one port(trunk) from new core to the old core(still in production) and provided ip from one of the vlan,
We got internet connectivity but my manager want's to login to it from different location using ssh...
06-07-2021 01:38 PM - edited 06-07-2021 01:40 PM
i do not see ssh configuration here? on your show run. (or am i missing something here ?)
can you post show ip ssh output
you can try telnet if that is open in your network to coming in
how are you trying to log in to this device ? from another cisco devices or from Linux or any ssh client?
06-07-2021 01:42 PM
ssh <ip>
what do I need to do please let me know
06-07-2021 01:43 PM
Configure below config :
ip ssh version 2
line vty 0 15
transport input ssh
privilege level 15
login local
tell us what SSH client you using to connect ?
06-07-2021 01:45 PM
I have console connection to this device(C-9300)
Using X-Shell to loging to the device
06-07-2021 01:54 PM - edited 08-10-2021 07:35 AM
Removing Config
06-07-2021 02:00 PM
Using X-Shell to loging to the device - is this client installed on Windows Pc ?
do you Putty or any other client to test.
06-07-2021 02:04 PM - edited 06-07-2021 02:05 PM
Yes, X-shell & Putty both are installed in Windows workstation.
Just now tried with Putty but no luck.. same, getting stuck with Connection Extablished message
06-07-2021 02:35 PM
I am glad to see the output of show ip ssh. It does confirm that ssh is configured and should be running. It shows that it is restricted to ssh version 2. I am not surprised that there is not much in the running config that shows ssh, but I am surprised that the restriction to version 2 does not show up. Are we sure that the client being used for testing is using ssh version 2? Perhaps testing with a different client might be something to try?
The posted config does show that ssh is enabled and that telnet is disabled. So testing with telnet is no longer an option.
I see this in the output and wonder if the issue might relate to the key size
Minimum expected Diffie Hellman key size : 2048 bits
I am very interested in this message that showed up
WARNING! The remote SSH server rejected X11 forwarding request.
Which does make me wonder if the issue is something about the client attempting to initiate the ssh connection. I would suggest that perhaps the next step would be to verify that logging is configured and working as expected, make sure that logging level is set to debug, and then run debug ip ssh, attempt the ssh connection, and post any debug output.
06-07-2021 02:44 PM - edited 06-07-2021 02:46 PM
Hi Richard,
I have enabled debug for ssh & icmp, but when I am trying to ssh or ping the IP, I don't see any debug message in the device console..
And just now enabled telnet as well, but not working
06-07-2021 02:49 PM - edited 08-10-2021 07:35 AM
removing config
06-07-2021 06:08 PM
Thanks for the additional information. If you are connected via the console I am surprised that you needed terminal monitor to see debug output. I would expect to need terminal monitor if you were connecting via telnet or SSH.
The output does confirm that there is some problem about SSH
*Jun 7 21:52:27.598: SSH2 1: SSH ERROR closing the connection
*Jun 7 21:52:27.598: SSH1: receive failure - status 0x03
Unfortunately I have no information about what status 0x03 means. If this switch is covered by a maintenance agreement I would suggest that you open a case with Cisco TAC. They would have information about what that error means.
