06-01-2026 10:32 PM
May 21 11:05:43.163: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 11:53:29.229: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:17:21.289: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:29:15.634: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:35:14.700: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:38:13.747: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:39:43.792: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 12:40:53.876: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 13:48:21.520: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 14:10:47.028: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 14:56:01.120: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
--More-- May 21 15:04:30.914: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:07:29.705: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:24:22.868: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:32:49.888: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:37:01.951: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:39:09.024: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:40:11.049: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e41f.d505.50fa reason CANT FORWARD
May 21 15:40:55.952: %DHCPD-7-NAK: DHCP nak sent to client 01e4.1fd5.0550.fa
May 22 15:15:36.761: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.10.85.
May 22 15:15:36.764: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.10.87.
May 22 15:15:36.765: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.10.88.
May 23 13:23:12.916: %SW_MATM-4-MACFLAP_NOTIF: Host c447.4e2d.043d in vlan 110 is flapping between port Te1/1/1 and port Gi1/0/17
--More-- May 25 05:30:51.562: %DHCPD-7-RELEASE: DHCP release request, client 0130.e3a4.9de8.dd
May 27 06:52:51.370: %DHCPD-7-NAK: DHCP nak sent to client 0128.7fcf.b107.42
May 29 08:57:36.270: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client e86a.648f.7f46 reason CLIENT CHANGED SUBNET
May 29 08:57:36.271: %DHCPD-7-NAK: DHCP nak sent to client 01e8.6a64.8f7f.46
May 29 09:29:09.546: %DHCPD-7-NO_LEASE: DHCP lease assignment failure, client 4c03.4ffc.1494 reason CLIENT CHANGED SUBNET
May 29 09:29:09.546: %DHCPD-7-NAK: DHCP nak sent to client 014c.034f.fc14.94
May 29 13:22:54.701: %DHCPD-7-NAK: DHCP nak sent to client 01e4.1fd5.0550.fa
May 29 13:34:21.728: %DHCPD-7-NAK: DHCP nak sent to client 0128.7fcf.b107.42
06-01-2026 11:15 PM
- @rcreddy-e Make sure to configure an ip helper address if the DHCP server is not on the
VLAN those clients are operating in : an example below.
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip helper-address 10.1.1.100
no shutdown
M.
06-01-2026 11:24 PM
No ip helper-address 10.1.1.100
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 8.8.4.4
lease 0 8
We have configured the DHCP pool for VLAN10 with the below settings:
Also, the ip helper-address 10.1.1.100 configuration is currently not enabled.
At present, devices with static IP addresses are working fine. However, DHCP IP addresses are not being assigned/released to client devices.
Could you please check and confirm if there are any missing configurations or issues from the DHCP server side?
Please let us know your observations.
06-01-2026 11:28 PM
- @rcreddy-e >....., the ip helper-address 10.1.1.100 configuration is currently not enabled.
If the DHCP server is not in Vlan10 then using the ip-helper address directive becomes
mandatory.
M.
06-02-2026 06:49 AM - edited 06-02-2026 06:57 AM
Hello @rcreddy-e ,
it looks like your switch is configured as DHCP server for VLAN10.
>> ip dhcp pool vlan10
lease 0 8
Configuration is fine if the switch has SVI interface vlan10 configured and up/up.
as suggested post also the configuration of interface vlan10 an outgoing IP ACL applied to it may be present.
check how many IP addresses are assigned from the pool
show ip dhcp binding
Edit:
view
Hope to help
Giuseppe
06-01-2026 11:21 PM
i guess you check the ip helper address and make sure not routing issues or firewall blocking UDP 67/68 traffic
06-01-2026 11:27 PM
whats your sh run int VLAN10 config ?
