11-27-2025 04:19 AM
Please wait while the system restarts.
Initializing Hardware...
System Bootstrap, Version 17.8.1r[FC2], RELEASE SOFTWARE (P)
Compiled Wed 01/26/2022 11:22:44.16 by rel
Current ROMMON image : Primary
Last reset cause : SoftwareReload
C9300L-48T-4X platform with 8388608 Kbytes of main memory
boot: attempting to boot from [usbflash0:cat9k_iosxe.17.15.04.SPA.bin]
boot: reading file cat9k_iosxe.17.15.04.SPA.bin
Warning: ignoring ROMMON var "BOOT_PARAM"
*Nov 27 11:27:16.419: %IOSXEBOOT-4-BOOTLOADER_UPGRADE: (rp/0): ### Thu Nov 27 11:27:16 Universal 2025 PLEASE DO NOT POWER CYCLE ### BOOTLOADER UPGRADING
MM [0] MCU version 68 sw ver 61
MCU UPGRADE IN PROGRESS... PLEASE DO NOT POWER CYCLE!!
Front-end Microcode IMG MGR: found 2 microcode images for 1 device.
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_10_1 update needed: yes
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_10_3 update needed: no
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0], index=0 ...
213072 bytes.
Front-end Microcode IMG MGR: Programming app image for device 0...
*Nov 27 11:29:07.292: %IOSXEBOOT-4-flashcp: (rp/0): polaris_franklin_rommon.bin
Nov 27 11:29:07.707: %PMAN-3-PROCHOLDDOWN: F0/0: pman: The process fed has been helddown (rc 139)
Front-end Microcode IMG MGR: MCU already in bootloader mode
0%!!!!!!!!!Nov 27 11:29:12.134: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process fed has failed (rc 139)
Nov 27 11:29:12.333: %PMAN-3-RELOAD_RP: F0/0: pvp: Reloading: Switch will be reloaded
Chassis 0 reloading, reason - Non participant detected
!waiting for upgrades to complete...
*Nov 27 11:29:13.322: %IOSXEBOOT-4-BOOTLOADER_UPGRADE: (rp/0): Thu Nov 27 11:29:13 Universal 2025 BOOTLOADER UPGRADE SUCCESSFUL
10%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
20%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
30%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
40%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
50%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
60%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
70%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
80%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
90%!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
EXTERNAL Hard Reset MCU after app download#
Front-end Microcode IMG MGR: Microcode programming complete for device 0.
Front-end Microcode IMG MGR: Preparing to program device[0], index=1 ...
11044 bytes.... Skipped[1].
Front-end Microcode IMG MGR: Microcode programming complete in 140 seconds
MCU UPGRADE COMPLETED!!...Nov 27 11:31:32.937: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Nov 27 11:33:04.201: %PMAN-0-PROCESS_NOTIFICATION: R0/0: pvp: The process lifecycle notification component failed because Processes Shutdown Timeout
Nov 27 11:33:05.292: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
Nov 27 11:33:10.854: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/RP_0-system-report_local_20251127-113305-Universal.tar.gz (size: 15378 KB) generated
System Bootstrap, Version 17.15.4r, RELEASE SOFTWARE (P)
Compiled Tue 06/10/2025 13:08:26.16 by rel
Last reset cause : LocalSoft
MM [0] MCU version 68 sw ver 68
Nov 27 11:38:36.696: %PMAN-3-PROCHOLDDOWN: F0/0: pman: The process fed has been helddown (rc 139)
Nov 27 11:38:41.125: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process fed has failed (rc 139)
Nov 27 11:38:41.323: %PMAN-3-RELOAD_RP: F0/0: pvp: Reloading: Switch will be reloaded
Nov 27 11:38:41.855: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Nov 27 11:40:13.114: %PMAN-0-PROCESS_NOTIFICATION: R0/0: pvp: The process lifecycle notification component failed because Processes Shutdown Timeout
Nov 27 11:40:14.180: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
Nov 27 11:40:19.531: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/RP_0-system-report_local_20251127-114014-Universal.tar.gz (size: 15353 KB) generated
Nov 27 11:44:58.644: %PMAN-3-PROCHOLDDOWN: F0/0: pman: The process fed has been helddown (rc 139)
Nov 27 11:45:03.072: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process fed has failed (rc 139)
Nov 27 11:45:03.276: %PMAN-3-RELOAD_RP: F0/0: pvp: Reloading: Switch will be reloaded
Nov 27 11:45:03.805: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Nov 27 11:46:34.997: %PMAN-0-PROCESS_NOTIFICATION: R0/0: pvp: The process lifecycle notification component failed because Processes Shutdown Timeout
Nov 27 11:46:36.069: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
Nov 27 11:46:41.421: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/RP_0-system-report_local_20251127-114636-Universal.tar.gz (size: 15352 KB) generated
Nov 27 11:51:20.071: %PMAN-3-PROCHOLDDOWN: F0/0: pman: The process fed has been helddown (rc 139)
Nov 27 11:51:24.502: %PMAN-0-PROCFAILCRIT: F0/0: pvp: A critical process fed has failed (rc 139)
Nov 27 11:51:24.707: %PMAN-3-RELOAD_RP: F0/0: pvp: Reloading: Switch will be reloaded
Nov 27 11:51:25.250: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Nov 27 11:52:56.476: %PMAN-0-PROCESS_NOTIFICATION: R0/0: pvp: The process lifecycle notification component failed because Processes Shutdown Timeout
Nov 27 11:52:57.540: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
Nov 27 11:53:02.886: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/RP_0-system-report_local_20251127-115257-Universal.tar.gz (size: 15354 KB) generated
11-27-2025 04:35 AM
hello @adityasharmalko1 This loop usually happens when the switch crashes right after loading IOS-XE, in ur logs it’s the FED process failing (rc 139), which points to a corrupted image or hardware issue on the forwarding engine. And u need to try some steps: Boot into ROMMON (break during startup). Verify the image. If the file is bad, re-copy a fresh image to USB and boot it manually... and If the FED continues to fail even with a clean image, it’s likely hardware failure and u’ll need an RMA.
And my friend this pattern is a known sign of hardware fault on C9300L.....
hope it helps and PEACE!
-Enes
11-27-2025 04:38 AM
and @adityasharmalko1 check this one;
https://www.router-switch.com/faq/catalyst-9300-boot-loop-troubleshooting.html
11-27-2025 04:46 AM
- @adityasharmalko1 FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb09284
M.
