11-21-2024 07:42 AM
Looking at C9300LM-48U-4Y for a customer. Fixed uplink and datasheet shows 25G. I can't find in the datasheets if it is backward compatible to 10G and 1G. The C9300X-NM-8Y module shows 25G/10G/1G in the datasheet. Would the C9300LM be backward compatible to anyones knowledge?
11-21-2024 12:50 PM
The uplinks are Fixed 25G only.
C9300LM-48UX-4Y |
48 port Cisco UPOE, 8 port 10G Multigigabit (10G/5G/2.5G/1G/100M) + 40 port 1G (1G/100M/10M) |
4x25G fixed uplinks |
11-21-2024 03:21 PM
Raise a TAC Case.
I am very sure that is a documentation "bug". Those ports are meant to support SFP/SFP+ as well as QSFP.
