C93180YC-FX can not saving running configuration
280120720
my 2 new C93180YC-FX swiches has made vpc redundant by using 3 DAC cable wire.
now find after restarted it can not saved running configuration.
1. can not using wr to save.
switch1# wr ?
erase Destroys the configuration on persistent media
switch1# wr
2. switch1# copy run start
[########################################] 100%
Copy complete, now saving to disk (please wait)...
Copy complete.
3. switch1# show version
Software
BIOS: version 05.47
NXOS: version 9.3(3)
BIOS compile time: 04/28/2022
NXOS image file is: bootflash:///nxos.9.3.3.bin
NXOS compile time: 12/22/2019 2:00:00 [12/22/2019 14:00:37]
Hardware
cisco Nexus9000 C93180YC-FX Chassis
Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 32827192 kB of memory.
Processor Board ID FDO27130KDM
Device name: cunchuswitch1
bootflash: 115805708 kB
Kernel uptime is 0 day(s), 19 hour(s), 39 minute(s), 41 second(s)
Last reset at 854305 usecs after Tue Nov 21 09:44:36 2023
Reason: Reset Requested by CLI command reload
System version: 9.3(3)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
6 Replies 6
There’s no write memory command on a Nexus switch. You use the copy run start command to save the configuration to NVRAM.
I think step of wr is deleted every config
I use copy run start I never use wr in nexus.
MHM
280120720
Yes, find no wr command. then I did using copy run start. i saw no any error.
but it can not saved after restarted.
You destroy config so copy run start dont save anything.
Change the name (for test) of nsk and copy run start and then restart
Check name.
280120720
Sorry,I'm not clear. how am i spposed to do? can you give an example?
You mention that you done below steps
1-make config
2-wr
3- copy run start
4-restart
5- check the config in first step and it lost
That what you do?
280120720
Yes. i did.
