C9500-40X Switch One Power Supply Disable Unable to Enable
brijesh yadav
Hi Team,
Kindly suggest I am unable to enable one Power supply by CLI on Switch C9500-40X. Find the below status of Power supply.
SW-95K#sh environment all
Switch 1 FAN 1 is OK
Switch 1 FAN 2 is OK
Switch 1 FAN 3 is OK
Switch 1 FAN 4 is OK
Switch 1 FAN 5 is OK
FAN PS-1 is NOT PRESENT
FAN PS-2 is OK
Switch 1: SYSTEM TEMPERATURE is OK
Inlet Temperature Value: 25 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 56 Degree Celsius
ASIC Temperature Value: 49 Degree Celsius
Yellow Threshold : 105 Degree Celsius
Red Threshold : 125 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C4-950WAC-R APS221400LX Disabled Bad Bad 950
1B PWR-C4-950WAC-R APS221400LE OK Good Good 950
I have run below command but still not work :- #power supply 1 slot A on
brijesh yadav
PDU source was fault from backend. Now resolved, thanks all for involving.
12 Replies 12
marce1000
      - Sometimes these outputs can be related to bugs. Can you check the (green) status-led on the power supply ?
 M.
Sure, I will check physical LED on power supply and get back.
i think it bug
when insert PSU but not connect power cable this bad bad appear.
check this link
https://bst.cisco.com/bugsearch/bug/CSCvb63422
LED is orange for disabled power supply. Other powers supply LED is green.
Re-seat the power supply.
Already done,but same issue.
RMA the power supply.
Orange LED indicates a faulty PS.
  - If it remains orange, check (input) feed , if that is OK ,then I guess the power supply is 'just bad' and you need to get another one.
 M.
Leo Laohoo
visually inspect the power feed of that power supply (inner).
marce1000
         - FYI https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk48435
 M.
brijesh yadav
