C9500 cpu queue statistics/policer problem
gabor_fejer
Level 2
Level 2
Hi All,
This morning, we have migrated from an old c3750  switch to a new c9500 stack solution, however, we are facing with a strange issue.
We use the equipment(s) for multicast traffic, and after the migration we noticed packet loss and drops on the control plane. This also affects the multicast/streaming service, some end-devices show "RTP sequence error".
We are suspecting these drops are being caused by the default cpu policer, however, when we have tried to increase the queue rate to 8000, the management of the sw did not respond. We had to console on to the sw and change the value back to the original one.
Have you ever experienced such a problem like this ?
Some outputs:
As you can see the  number of drops is huge in Queue RPF failed and MCAST DATA. What can cause this ?
c9500-sw#sh platform hardware fed switch 2 qos queue stats internal cpu policer
                         CPU Queue Statistics
                                              (default) (set)     Queue        Queue
QId PlcIdx  Queue Name                Enabled   Rate     Rate      Drop(Bytes)  Drop(Frames)
0    11     DOT1X Auth                  Yes     1000      1000     0            0
1    1      L2 Control                  Yes     2000      2000         0            0
2    14     Forus traffic               Yes     4000      4000         0            0
3    0      ICMP GEN                    Yes     750       750          0            0
4    2      Routing Control             Yes     5500      5500      0            0
5    14     Forus Address resolution    Yes     4000      4000     0            0
6    0      ICMP Redirect               Yes     750       750        0            0
7    16     Inter FED Traffic           Yes     2000      2000      0            0
8    4      L2 LVX Cont Pack            Yes     1000      1000     0            0
9    19     EWLC Control                Yes      13000     13000    0            0
10   16     EWLC Data                   Yes      2000      2000       0            0
11   13     L2 LVX Data Pack           Yes    1000      1000       0            0
12   0      BROADCAST                   Yes     750       750        0            0
13   10     Openflow                      Yes        250       1000         0            0
14   13     Sw forwarding               Yes     1000      1000     0            0
15   8      Topology Control            Yes     13000     16000    0            0
16   12     Proto Snooping              Yes     2000      2000     0            0
17   6      DHCP Snooping               Yes     500       500      0            0
18   13     Transit Traffic             Yes     1000      1000        0            0
19   10     RPF Failed                  Yes     250       1000       1163084619371  683470015
20   15     MCAST END STATION           Yes     2000         2000     0            0
21   13     LOGGING                     Yes     1000      1000     0            0
22   7      Punt Webauth                Yes     1000      1000     0            0
23   18     High Rate App               Yes     13000     13000    0            0
24   10     Exception                   Yes     250       1000     0            0
25   3      System Critical             Yes     1000      1000     0            0
26   10     NFL SAMPLED DATA            Yes     250       1000     0            0
27   2      Low Latency                 Yes     5500      5500     0            0
28   10     EGR Exception               Yes     250       1000     0            0
29   5      Stackwise Virtual OOB       Yes     8000      8000     0            0
30   9      MCAST Data                  Yes     500       1000     14651359982  10118797
31   3      Gold Pkt                    Yes     1000      1000     0            0
* NOTE: CPU queue policer rates are configured to the closest hardware supported value
                      CPU Queue Policer Statistics
Policer    Policer Accept   Policer Accept  Policer Drop  Policer Drop
  Index         Bytes          Frames        Bytes          Frames
0          22787            73              0             0
1          1404977          10536           0             0
2          15951            224             0             0
3          3700714          10901           0             0
4          0                0               0             0
5          2058524250       3719854         0             0
6          0                0               0             0
7          0                0               0             0
8          248547           2448            0             0
9          3373800700       2451384         14651359982   10118797
10         4155548760       2451384         1163084731003   683470085
11         0                0               0             0
12         0                0               0             0
13         118              1               0             0
14         1171146          12179           0             0
15         325970           4920            0             0
16         0                0               0             0
17         0                0               0             0
18         0                0               0             0
19         0                0               0             0
                  Second Level Policer Statistics
20         1669475          13208           0             0
21         7530628151       4919800         0             0
c9500-sw#ping 10.10.25.46 sou vlan40 rep 400
Sending 400, 100-byte ICMP Echos to 10.10.25.46, timeout is 2 seconds:
Packet sent with a source address of 10.10.25.62
Success rate is 96 percent (384/400), round-trip min/avg/max = 1/1/5 ms
c9500-sw#show platform software fed switch active cpu-interface
queue                      retrieved   dropped     invalid     hol-block
Routing Protocol           102685      0           0           0
L2 Protocol                10812722    0           0           0
sw forwarding              386         3           0           0
broadcast                  16479       0           0           0
icmp gen                   0           0           0           0
icmp redirect              0           0           0           0
logging                    0           0           0           0
rpf-fail                   161538486   0           0           0
DOT1X authentication       0           0           0           0
Forus Traffic              6146593     0           0           0
Forus Resolution           127235      0           0           0
Inter FED                  0           0           0           0
L2 LVX control             0           0           0           0
EWLC control               0           0           0           0
EWLC data                  0           0           0           0
L2 LVX data                0           0           0           0
Openflow                   0           0           0           0
Topology control           966672      0           0           0
Proto snooping             0           0           0           0
DHCP snooping              0           0           0           0
Transit Traffic            0           0           0           0
Multi End station          903713      0           0           0
Webauth                    0           0           0           0
High rate app              0           0           0           0
Exception                  0           0           0           0
System Critical            5698491     0           0           0
NFL sampled data           0           0           0           0
Low latency                0           0           0           0
EGR exception              6           0           0           0
Stackwise Virtual OOB      440307201   0           0           0
Multicast data             311391329   0           0           0
Gold packet                52          0           0           0
CPU utilisation is not more than 50%.
How could we resolve this problem ?
Thank you very much for your help and support in advance.
Shaun_Vizer
Frequent Visitor
Frequent Visitor
Am curious if you were able to resolve the issue and if so, what was the solution to fix?
Cheers
Same ^^
