C9500 Install Mode issue
philasam79
Hi folks. I'm trying to upgrade my C9500 that is in VSS to IOS image Cat9k_iosxe.17.03.04.SPA.bin in install mode. when i issue the command "install add file flash:Cat9k_iosxe.17.03.04.SPA.bin activate ISSU commit. It fails to perform the upgrade. I discovered that the "packages.conf" file isn't in the flash.
How can i get it back in the flash to be able to perform the ISSU upgrade successfully?
29 Replies 29
philasam79
Hi Leo,
I'm not sure what you are trying to advise here. I have tried the steps mentioned in the PDF. Right after your last comment came in. I issue "install remove inactive" command on the switch. This command was completed. However, there was no install files to be removed as the same files in my "Flash" are still the file there after the install remove inactive was completed. The question i wish you could answer is "If there is no packages.conf" file or any ".PKG" file in the flash, where will the install process find packages.conf to boot from?
See below result of my boot variable. this was after i had issued the install remove inactive command and set the boot variable. However, after this the appropriate image was tranfered to the switch and when i issued the "install add file flash:cat9k_iosxe.17.03.04.SPA.bin activate commit" I get this error"c9500_core#$ file flash:cat9k_iosxe.17.03.04.SPA.bin activate commit
install_add_activate_commit: START Sat Nov 27 01:38:18 UTC 2021
FAILED: install_add_activate_commit : Install ISSU in progress. Abort the ISSU upgrade to proceed
c9500_core#
*Nov 27 01:38:18.546: %INSTALL-5-INSTALL_START_INFO: Switch 2 R0/0: install_engine: Started install one-shot flash:cat9k_iosxe.17.03.04.SPA.bin
*Nov 27 01:38:18.845: %INSTALL-3-OPERATION_ERROR_MESSAGE: Switch 2 R0/0: install_engine: Failed to install_add_activate_commit package flash:cat9k_iosxe.17.03.04.SPA.bin, Error: install_add_activate_commit : Install ISSU in progress. Abort the ISSU upgrade to proceed"
c9500_core#sh boot
Switch 2
Current Boot Variables:
BOOT variable = flash:packages.conf;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
81921 drwx 4096 Nov 27 2021 01:26:31 +00:00 .installer
442381 -rw- 616 Nov 27 2021 01:23:12 +00:00 stby-vlan.dat
49155 -rw- 2097152 Nov 27 2021 01:21:12 +00:00 nvram_config_bkup
49154 -rw- 2097152 Nov 27 2021 01:21:12 +00:00 nvram_config
49159 -rw- 0 Nov 27 2021 01:21:10 +00:00 dope_hist
442383 -rw- 16984 Nov 27 2021 01:21:10 +00:00 rdope_out.txt
442384 -rw- 89 Nov 27 2021 01:21:09 +00:00 rdope.log
442387 -rw- 5242880 Nov 27 2021 01:19:44 +00:00 ssd
442376 -rwx 2049 Nov 27 2021 01:19:24 +00:00 svl_ipc.tcl
442377 -rw- 134458 Nov 27 2021 01:19:24 +00:00 memleak.tcl
49156 -rw- 312 Nov 27 2021 01:19:14 +00:00 boothelper.log
131073 drwx 4096 Nov 27 2021 01:19:13 +00:00 dc_profile_dir
442375 -rw- 1739 Nov 27 2021 01:19:04 +00:00 bootloader_evt_handle.log
98305 drwx 4096 Nov 26 2021 19:00:16 +00:00 .prst_sync
49162 -rw- 439 Nov 26 2021 18:16:03 +00:00 capsule-upgrade.log
229377 drwx 4096 Nov 25 2021 13:47:57 +00:00 .rommon_sync
49160 -rw- 616 Nov 25 2021 13:32:36 +00:00 vlan.dat
147457 drwx 4096 Nov 24 2021 23:02:23 +00:00 .dbpersist
49161 -rw- 12242 Nov 24 2021 23:01:55 +00:00 running_config
49158 -rw- 907450095 Nov 24 2021 18:33:51 +00:00 cat9k_iosxe.17.03.04.SPA.bin
221185 drwx 4096 Nov 18 2021 03:06:34 +00:00 Tbot
81967 drwx 4096 Nov 18 2021 03:06:28 +00:00 sys_report
81922 drwx 4096 Nov 18 2021 03:06:28 +00:00 tech_support
122881 drwx 4096 Nov 18 2021 03:06:28 +00:00 gs_script
81960 drwx 4096 Nov 18 2021 03:06:26 +00:00 ss_disc
442380 -rw- 116459 Nov 17 2021 22:39:07 +00:00 pnp-tech-discovery-summary
442379 -rw- 35 Nov 17 2021 22:39:04 +00:00 pnp-tech-time
155649 drwx 4096 Apr 30 2021 00:20:10 +00:00 onep
90113 drwx 4096 Jan 28 2019 10:32:38 +00:00 core
114689 drwx 4096 Jan 28 2019 10:31:12 +00:00 .rollback_timer
FYI: This is not the first time i'm doing this install. I have more than 50 Cat9k in my infrastructure. I have done this 10s to 50 times. However, i have never come across a situation where, "packages.conf" or Pkg files aren't in the flash. If you can tell me how to get "packages.conf" in the flash, i could so much appreciate that.
philasam79
c9500_core#install add file flash:cat9k_iosxe.17.03.03.SPA.bin activate commit
install_add_activate_commit: START Sat Nov 27 01:54:01 UTC 2021
System configuration has been modified.
Press Yes(y) to save the configuration and proceed.
Press No(n) for proceeding without saving the configuration.
Press Quit(q) to exit, you may save configuration and re-enter the command. [y/n/q]yBuilding configuration...
[OK]Modified configuration has been saved
c9500_core#
*Nov 27 01:54:06.663: %INSTALL-5-INSTALL_START_INFO: Switch 1 R0/0: install_engine: Started install one-shot flash:cat9k_iosxe.17.03.03.SPA.bin
*Nov 27 01:54:06.959: %INSTALL-3-OPERATION_ERROR_MESSAGE: Switch 1 R0/0: install_engine: Failed to install_add_activate_commit package flash:cat9k_iosxe.17.03.03.SPA.bin, Error: install_add_activate_commit : Install ISSU in progress. Abort the ISSU upgrade to proceed
Can you try the following command:
install abort issu
Can I see the complete output to the command "sh version".  What I want to see are the following:
  • What is the current IOS-XE version; and
  • What is uptime
The Install Mode will extract the necessary package files from the BIN file.  If the process works, it will also create a packages.conf file.  Remember, "if the process works".  In some documents, I have a "gotchas" section and this only applies when the system is unable to create the "packages.conf" file and manual intervention is required.
philasam79
I have ran this command "install abort issue" more than 5 times today and tried to attempt the install over and over again. Everytime, i abort the install, i get the same error right when i tried to install the image.
c9500_core#install abort issu
install_abort: START Sat Nov 27 02:26:45 UTC 2021
NOTE: Going to start Abort ISSU install process
STAGE 0: System Level Sanity Check
/usr/binos/conf/install_util.sh: line 688: /bootflash/.installer/install_add_pkg_list.txt: No such file or directory
Standby is not online. User can manually abort the ISSU
operation once Standby is online
ERROR: install_abort exit(2 ) Sat Nov 27 02:26:45 UTC 2021
c9500_core#sh version
Cisco IOS XE Software, Version 17.03.04
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 03-Jul-21 01:55 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.2r, RELEASE SOFTWARE (P)
c9500_core uptime is 1 hour, 6 minutes
Uptime for this control processor is 1 hour, 8 minutes
System returned to ROM by SSO Switchover
System image file is "flash:cat9k_iosxe.17.03.04.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9500-40X (X86) processor with 1331366K/6147K bytes of memory.
Processor board ID xxxxxxxx
2 Virtual Ethernet interfaces
96 Ten Gigabit Ethernet interfaces
4 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
15662080K bytes of USB Flash at usbflash0:.
Base Ethernet MAC Address : 00:2f:5c:0x:0c:00
Motherboard Assembly Number : 73-18140-03
Motherboard Serial Number : T
Model Revision Number : D0
Motherboard Revision Number : B0
Model Number : C9500-40X
System Serial Number :
CLEI Code Number :
Switch Ports Model SW Version SW Image Mode
* 1 50 C9500-40X 17.03.04 CAT9K_IOSXE BUNDLE
Right, this leaves only one option left:  Reboot the appliance one more time and then re-run the Install Mode command.
philasam79
I set the boot variable to "boot flash:packages.conf".
Remember that i had said that if packages.confi is not present in the flash:, the install will not know where to locate the file? Hence, during a reboot, there will be an ERROR.
This is the boot ERROR.
Initializing Hardware...
Compiled Wed 10/23/2019 16:35:17.50 by rel
Current ROMMON image : Primary
Last reset cause : PowerOn
C9500-40X platform with 16777216 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf]
ERROR: failed to boot from flash:packages.conf (Not Found)
Now that the switch is in ROMMON, i had to boot it with the image directly.
switch:
switch: boot flash:cat9k_iosxe.17.03.03.SPA.bin
boot: attempting to boot from [flash:cat9k_iosxe.17.03.03.SPA.bin]
boot: reading file cat9k_iosxe.17.03.03.SPA.bin
THIS IS THE OUTPUT OF THE SHOW VERSION AFTER I DECIDED TO BOOT WITH THE .BIN FROM ROMMON.
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.3, RELEASE SOFTWARE (fc7)
Compiled Thu 04-Mar-21 12:32 by mcpre
software.
ROM: IOS-XE ROMMON
c9500_core uptime is 0 minutes
Uptime for this control processor is 4 minutes
System returned to ROM by Reload Command
System image file is "flash:cat9k_iosxe.17.03.03.SPA.bin"
Last reload reason: Reload Command
export@cisco.com.
cisco C9500-40X (X86) processor with 1331521K/6147K bytes of memory.
Processor board ID XXXXXXXXXXXXX
Base Ethernet MAC Address : 00:2f:5c:03:2c:80
Motherboard Serial Number : XXXXXXXXXXXXXXX
System Serial Number : XXXXXXXXXXXXXXXXX
CLEI Code Number :
* 1 50 C9500-40X 17.03.03 CAT9K_IOSXE BUNDLE
Configuration register is 0x102
After the reboot, execute this command:
If this does not work, I have one more trick to do, however, export the switch config externally.
philasam79
Ran the command after the reboot. This is the ERROR. The same error is what i will also get after i have ran "install abort issu.
c9500_core#install add file flash:cat9k_iosxe.17.03.04.SPA.bin activate commit
install_add_activate_commit: START Sat Nov 27 03:00:32 UTC 2021
c9500_core#
*Nov 27 03:00:33.199: %INSTALL-5-INSTALL_START_INFO: Switch 1 R0/0: install_engine: Started install one-shot flash:cat9k_iosxe.17.03.04.SPA.bin
*Nov 27 03:00:33.491: %INSTALL-3-OPERATION_ERROR_MESSAGE: Switch 1 R0/0: install_engine: Failed to install_add_activate_commit package flash:cat9k_iosxe.17.03.04.SPA.bin, Error: install_add_activate_commit : Install ISSU in progress. Abort the ISSU upgrade to proceed
Ok, one last trick -- And this is going to be "NSFW".
  1. Format the flash of the switch (Command:  format flash:)
  2. Reboot the switch, and because packages.conf is not present, it will go into ROMMON.
  3. After the flash gets formatted, copy the IOS-XE from the USB thumb drive to the switch.
  4. Boot the IOS-XE BIN file from ROMMON.
  5. Re-run the Install Mode command.
philasam79
Thank you Leo for your consistent followup. It didn't appear to me that my images in the flash may be corrupt. After i formatted the flash. I i rebooted the chassis from ROMMON with the .BIN extension. After a complete boot, i copied the image to flash and repeated the install and this time, it was successful. Much appreciation.
The BIN file was-not and never-was corrupt.
Here are several "take-aways" to consider:
  1. Please "minimize" using ISSU, FSU/eFSU.
  2. Cold reboot is more valuable than "FastReload".
DonaldWB
I spoke with TAC on this and if you verify that your "more packages.conf" and "more flash-2:packages.conf" are pointing to the same file (can verify via looking to see if they have the same shalsum marker if nothing else.)
then you should be able to perform the following commands in order to clear the state that the switch is in and allow you to proceed:
conf t
service internal
exit
clear install state
conf t
no service internal
Afterwards when I did a "show issu stat detail" it gave me the current ISSU Status: Enabled
  1. conf t
  2.  no boot system
  3. boot system bootflash:packages.conf
  4. exit
  5. install add file bootflash:FirmwareFile.bin activate commit
  6. y (to save the configuration and proceed)
And viola Updated firmware just fine after that
this works. you save my ass. thank bro
Saved my ass as well. Beer is on me at Cisco Live!
Alex Martin
I'm late to the party here, but I ran across this post yesterday and had the same issue and after contacting TAC, this is what the engineer did to fix my issue so I thought I would share and maybe help someone else out that has this same issue that doesn't seem to have a good answer anywhere on the web that I have seen.  Take this for what it is as my issue was not on a 9500, but rather a 9400, but I would guess it would be the same issue.
Switch#configure terminal
Switch(config)#service internal
Switch(config)#exit
Switch#clear install state
clear_install_state: START Sun Jul 14 12:49:10 CDT 2024
--- Starting clear_install_state ---
Performing clear_install_state on Active/Standby
[1] clear_install_state package(s) on R0
[1] Finished clear_install_state on R0
[1] clear_install_state package(s) on R1
[1] Finished clear_install_state on R1
Checking status of clear_install_state on [R0 R1]
clear_install_state: Passed on [R0 R1]
Switch(config)#no service internal
Switch(config)#exit
From this point you can check the ISSU Status (show issue state detail) and you should see 'No ISSU operation is in progress'. From here, you should be good to perform the upgrade without any issue.
- Hope this helps
