C9500 rack installation question (cage nuts & grounding wire)
AK72495
We are looking to purchase M6 cage nuts to use for the C9500. Would that work with installing it into the rack?
For the grounding wire, is there a specific part number that Cisco has for it or do we just use any third-party grounding wire?
Thank you.
Reza Sharifi
You can use any third-party grounding wire. It really does not matter what you use as long as it is grounded.
Thank you. Do you happen to know anything about the cage nuts? We have a 19-inch SGI rack that is square hole, but the type of switch we are trying to purchase comes with M4 screws (C9500-40X-A). We're just trying to figure out if M6 would work.
When you purchase a rach or cabinet, the cage nuts usually come with it in a plastic bag. If not, to get the right one, I recommend asking the tech support where you purchased it.
