cable modem and cisco 2600
favioscar69
Hi!
I'm trying to configure a cisco router 2600, my internet connection is via a cable modem. I get a dynamic IP from the cable modem but when I ping to any external IP I have errors.Copy show config and show interface f0/1
GUEST#show config
Using 1103 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname GUEST
enable secret 5 $1$JK3y$ns4oiH0tN0XAPk8G7JOwS/
enable password 123456789
ip subnet-zero
ip name-server dns provider1
ip name-server dns provider2
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN-INTERNA
   network 192.168.1.0 255.255.255.0
   dns-server dns provider1 dns provider2
call rsvp-sync
interface FastEthernet0/0
description LAN-INTERNA
ip nat inside
no ip mroute-cache
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
description INTERNET
ip address dhcp
ip nat outside
no ip mroute-cache
duplex auto
speed auto
ip nat inside source list 100 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
no ip http server
access-list 100 permit ip any any
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password 123456789
login
end
GUEST#show interface f0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is AmdFE, address is 0005.5e63.77c1 (bia 0005.5e63.77c1)
  Description: INTERNET
  Internet address is a.b.c.d/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:02, output hang never
  Input queue: 2/75/556/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 26000 bits/sec, 41 packets/sec
     10632 packets input, 666156 bytes
     Received 10632 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     45 packets output, 5319 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
GUEST#ping www.google.com
Translating "www.google.com"...domain server (dns provider1) (dns provider2)
% Unrecognized host or address, or protocol not running.
GUEST#ping w.x.y.z
Sending 5, 100-byte ICMP Echos to w.x.y.z, timeout is 2 seconds:
Success rate is 0 percent (0/5)
John Blakley
Favio,
Try changing your acl for nat to:
no access-list 100
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
And delete the ip route statement:
HTH,
John
HTH, John *** Please rate all useful posts ***
Your DHCP server is not serving a default gateway, so any traffic you send from a PC will not be able to get off the network. Also, for you to ping by name, make sure you use a valid DNS provider for the name server.
I would try pinging 4.2.2.2 which is a known good internet DNS server. Kind of two birds with one stone, it's handy to ping to test and you can use it for DNS in a pinch. 8.8.8.8 and 8.8.4.4 are good to use also, they are google DNS servers.
Good luck!
Andy
Thanks its working!
