Cabling question
Junaid Shah
Level 3
Level 3
Hello
I have connected a cisco 3750 switch with cisco 2951 router. I have connected them through straight cable. Do i need to use cross cable ? and below are the results of tdr test. Does this indicate that cable is faulty and needs to be changed or i have to change cable type at all. Thanks in advance
PAK3750-1#show cable-diagnostics tdr inter gi 1/0/16
TDR test last run on: October 03 14:33:57
Interface Speed Local pair Pair length        Remote pair Pair status
  100M      Pair A     2    +/- 4  meters Pair A      Normal
                Pair B     2    +/- 4  meters Pair B      Normal
                Pair C     4    +/- 4  meters Pair C      Short
                Pair D     4    +/- 4  meters Pair D       Short
Lei Tian
Straight or crossover doesnt matter. The switch support auto MDIX. Yes, the cable is problem. You should see normal for all pair.
HTH,
Lei Tian
