Bookmark
Subscribe
1701
Calculating subents from IP Range
mahesh18
Level 6
Level 6
Hi Everyone,
Need to confirm which subnets will this IP cover
IP 172.16.0.0/12
Will this cover whole range  - 172.16.0.0 to 172.31.255.254
Mahesh
Message was edited by: mahesh parmar
4 Accepted Solutions
Bilal Nawaz
Hello Mahesh you are correct.
here are the details for your /12 address range:
172.16.0.0/12
host range 172.16.0.1 - 172.31.255.254 (available addresses)
Network address 172.16.0.0
Broadcast address 172.31.255.255
Wildcard mask 0.15.255.255
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
Yes IP 172.16.0.0/12 = 172.16.0.1 to 172.31.255.255
Res
Paul
Kind Regards
Paul
Hi Mahesh,
Here is the calculator for you to check by yourself incase required in future:
http://www.subnetonline.com/pages/subnet-calculators/ip-subnet-calculator.php
http://www.subnet-calculator.com/
Inayath
Hi Mahesh,
It doesn calculate just key in the correct ip address and respective subnet mask and hit the calculate button on this link:
or the other easiet for you to check is:
http://jodies.de/ipcalc
ip address: 172.16.0.0/12
Address (Host or Network)Netmask (i.e. 24)Netmask for sub/supernet (optional)
/move to:
Address:   172.16.0.0            10101100.0001 0000.00000000.00000000
Netmask:   255.240.0.0 = 12      11111111.1111 0000.00000000.00000000
Wildcard:  0.15.255.255          00000000.0000 1111.11111111.11111111
=> Network:   172.16.0.0/12         10101100.0001 0000.00000000.00000000 (Class B)
Broadcast: 172.31.255.255        10101100.0001 1111.11111111.11111111
HostMin:   172.16.0.1            10101100.0001 0000.00000000.00000001
HostMax:   172.31.255.254        10101100.0001 1111.11111111.11111110
Hosts/Net: 1048574               (Private Internet)
Key in the ip address and netmask it will show you the subnet range.
Inayath
7 Replies 7
Bilal Nawaz
172.16.0.0/12
Hope this helps
Hello
Res
Paul
Kind Regards
Paul
Many thanks for confirming this one
MAhesh
Hi Mahesh,
Inayath
Hi Inayath,
But this does not calculate 172.16.0.0/12.
MAhesh
Hi Mahesh,
/move to:
Inayath
Hi Inayath,
these  2 new links calculate.
These will be hand in future
Mahesh
