Calculating Switch Power Requirements for VoIP
mario3
I am planning for a VoIP install and I need to make sure we have enough power on the 3850 switch to support the phones. The phones consume 13 watts max, switch is 48 ports, there will be a phone plugged into each port, available watts per switch module in 5 switch stack is 420 watts, and each switch has one 715 watt power supply. How do I calculate how much power I will need to support all of the phones? Is it as simple as multiplying the phone wattage by number of ports and comparing to available watts for the switch module?
Giuseppe Larosa
Hello Mario3,
you would need at least 13W *48 for the phones and you need also to provide power to make the switch to stay alive and function correctly.
13W*48 = 620 W   you would need this power avaiable for POE
if you power supply is only 715W I am afraid you will not be able to put a phone on each port.
I think you would need a 900W power supply as minimum.
To support also more demanding POE devices 1100W power supplies are used.
see the datasheet
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
for 48 ports POE+ or UPOE you need a 1100 W PS with 800 W available for POE.
Also what happens in your stack if one power supply fails ?
you should deploy redundant power supplies on each switch
Dual redundant modular power supplies
The Cisco Catalyst 3850 Series Switches support dual redundant power supplies.[6] The switch ships with one power supply by default, and the second power supply can be purchased at the time of ordering the switch or at a later time. If only one power supply is installed, it should always be in power supply bay 1. The switch also ships with three field-replaceable fans
or you should use 1100W PS and stack power cables
>>>Cisco StackPower® technology provides power stacking among stack members for power redundancy
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mario3,
see the datasheet
Hope to help
Giuseppe
Giuseppe,
Thanks! This is what I was trying to confirm.
