Cisco 9500
eroparkERI
I have a Cisco 9500 in my network that I need to set the
SSL/TLS to v1.2 . Would anyone happen to know the
procedure to do so ?
RDP
Reza Sharifi
Most newer devices by default support ssh version 2 and I don't see an option to set it to 1.2, however if your client support 1.2 only, it should be backward compatible with 2.0
Could it be done by creating a self signed cert and setting the SSL/TLS to v1.2 ?
RDP
Not sure if that is possible. You may want to open a ticket with Cisco TAC and have their developers provide feedback.
I believe you are correct here....I'll reach out to the TAC and see what they say but I do not
think this is possible...
RDP
