can i config etherchannel loadbalance base on interface port-channel? not global on nexus 7000?
fly
Level 2
Level 2
Dear Sir/Madam,
    same question on nexus 7000
   I know i can  config etherchannel load balance base on global ,and module.
   I want to config different etherchannel loadbalance method on different interface port channel on nexus 7000 or other nexus product
  such as
   interface po1 src-mac dst-mac
   interface po10 src-ip dst ip
   interface po 20 src-port dst-port
   thank you
tom
Mark Malone
you cant do it per port-channel but you can set it globally or per module , that's the limitation of the hardware
switch# configure terminal
switch (config)# port-channel load-balance source-ip-port module 5
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_portchannel.html#83975
