Can I upgrade cisco 3750 switch from 12.2(53r) to 15.2(1)E2 without any issues?
phani.raju
Hi All,
Or is there any upgrade path to follow to reach 15.2(1)E2.
Thank You,
P Phani.
Leo Laohoo
"without any issues" is an understatement if you are talking about IOS train 15.2(1)E.   I would recommend you test this IOS on a stand-alone (fully configured) 3750 and see for yourself.  As for me, I downgraded to 15.0(2)SE4 because the entire 15.2(1)E train is riddled with CPU bugs.
Another thing, what exact model of 3750?  If you have a 3750 with only 16 mb flash, then the highest IOS you can upgrade to is 12.2(55)SE train.  This train, 12.2(55)SE9, is deemed as the most stable IOS.
Hi Leo,
Here is the details:
Model number                    : WS-C3750X-48P-S
Directory of flash:/
  518  -rwx        4120  Apr 23 2014 19:50:25 +01:00  multiple-fs
    2  -rwx        7666   Nov 7 2013 16:47:53 +00:00  private-config.text.renamed
    3  -rwx       54502  Jul 18 2013 12:21:04 +01:00  config.text.backup
    4  -rwx         856   Mar 1 1993 00:01:45 +00:00  vlan.dat
    5  -rwx       54993   Nov 7 2013 16:47:53 +00:00  config.text.renamed
    6  drwx         512   Mar 1 1993 00:11:16 +00:00  c3750e-universalk9-mz.122-55.SE5
  514  -rwx        7666  Jul 18 2013 12:21:04 +01:00  private-config.text.backup
  515  -rwx        5505  Apr 23 2014 19:50:25 +01:00  private-config.text
  517  -rwx       54444  Apr 23 2014 19:50:24 +01:00  config.text
57671680 bytes total (37879808 bytes free)
These are the stack switches.
Thank You,
Ok, you can use 15.X IOS.
