Can not ping
Not applicable
Hello
I can ping ip 10.10.10.10 but can not ping ip 10.10.10.16 from internet router?!
Jeddah#ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Jeddah#ping 10.10.10.16
Sending 5, 100-byte ICMP Echos to 10.10.10.16, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Jeddah#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 10.100.100.1 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected
is directly connected, GigabitEthernet0/0
1.0.0.0/24 is subnetted, 1 subnets
S 1.1.1.0 [1/0] via 10.100.100.1
10.0.0.0/8 is variably subnetted, 20 subnets, 3 masks
C 10.10.8.0/24 is directly connected, GigabitEthernet0/1.10
L 10.10.8.254/32 is directly connected, GigabitEthernet0/1.10
C 10.10.9.0/24 is directly connected, GigabitEthernet0/1.20
L 10.10.9.2/32 is directly connected, GigabitEthernet0/1.20
C 10.10.10.0/24 is directly connected, GigabitEthernet0/1.30
L 10.10.10.2/32 is directly connected, GigabitEthernet0/1.30
C 10.10.99.0/24 is directly connected, GigabitEthernet0/1.99
L 10.10.99.254/32 is directly connected, GigabitEthernet0/1.99
S 10.11.10.0/24 [1/0] via 10.100.100.1
C 10.11.12.1/32 is directly connected, Loopback0
S 10.12.10.0/24 [1/0] via 10.100.100.1
C 10.68.8.64/30 is directly connected, GigabitEthernet0/2
L 10.68.8.66/32 is directly connected, GigabitEthernet0/2
C 10.100.100.0/24 is directly connected, GigabitEthernet0/0
L 10.100.100.2/32 is directly connected, GigabitEthernet0/0
L 10.100.100.3/32 is directly connected, GigabitEthernet0/0
L 10.100.100.4/32 is directly connected, GigabitEthernet0/0
S 10.100.110.0/24 [1/0] via 10.100.100.1
S 10.100.120.0/24 [1/0] via 10.100.100.1
S 10.208.9.69/32 [1/0] via 10.68.8.65
11.0.0.0/24 is subnetted, 1 subnets
S 11.11.11.0 [1/0] via 10.100.100.1
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
S 172.16.16.0/24 [1/0] via 10.10.10.1
C 172.16.32.0/24 is directly connected, GigabitEthernet0/1.50
L 172.16.32.2/32 is directly connected, GigabitEthernet0/1.50
Jeddah#
Edge router
wafai#ping 10.10.10.10
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
wafai#ping 10.10.10.16
Success rate is 0 percent (0/5)
wafai#show ip route
Gateway of last resort is 185.51.204.29 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 185.51.204.29
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/24 is directly connected, Tunnel0
L 1.1.1.1/32 is directly connected, Tunnel0
10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
S 10.10.9.0/24 [1/0] via 10.100.100.2
S 10.10.10.0/24 [1/0] via 10.100.100.2
S 10.11.10.0/24 [1/0] via 1.1.1.3
S 10.12.10.0/24 [1/0] via 1.1.1.2
C 10.100.100.0/24 is directly connected, Vlan1
L 10.100.100.1/32 is directly connected, Vlan1
S 10.100.110.0/24 [1/0] via 1.1.1.2
S 10.100.120.0/24 [1/0] via 1.1.1.3
172.16.0.0/24 is subnetted, 1 subnets
S 172.16.32.0 [1/0] via 10.100.100.2
185.51.0.0/16 is variably subnetted, 5 subnets, 3 masks
C 185.51.204.28/30 is directly connected, FastEthernet4
L 185.51.204.30/32 is directly connected, FastEthernet4
C 185.51.207.120/29 is directly connected, Vlan1
L 185.51.207.121/32 is directly connected, Vlan1
L 185.51.207.123/32 is directly connected, Vlan1
wafai#
kindly support me.....
14 Replies 14
hard to say without seeing the configurations of both routers, can you post those ?
Thank you for your interested,
Please find attached file
From: Jeddah_internal-router => I can ping 10.10.10.10 and 10.10.10.16
From Wafai_Internet-router => I can ping 10.10.10.10 but can not ping 10.10.10.16
Jeddah_internal-router < === direct link 10.100.100.0/24 ===> wafai_internet-router
from what I can tell, ICMP originating from 10.10.10.16 on the Jeddah router gets NATed to 10.100.100.4 (since you have specified that in extended access list BILLING). ICMP from 10.10.10.10 does get NATed to interface GigabitEthernet0/0. That might be the difference.
Try to take the below line out of access list BILLING:
ip access-list extended BILLING
permit tcp host 10.10.10.16 any eq www
permit tcp host 10.10.10.16 any eq 8080
--> no permit icmp host 10.10.10.16 any
Hello
Still the same issue
Hello
FYI - Nat isnt being used here as the WAFI rtr have a static route back to 10.10.10.0/24 subnet via its vlan 1 interface
Can you try ping from WAFI again but this time
ping 10.10.10.10 source vlan 1
ping 10.10.10.16 source vlan 1
sh ip arp
res
Paul
Kind Regards
Paul
wafai#ping 10.10.10.10 source vlan 1
Packet sent with a source address of 10.100.100.1
wafai#ping 10.10.10.16 source vlan 1
wafai#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.100.100.1 - ecbd.1d60.afb8 ARPA Vlan1
Internet 10.100.100.2 1 0462.73ce.be20 ARPA Vlan1
Internet 10.100.100.3 144 0462.73ce.be20 ARPA Vlan1
Internet 10.100.100.4 152 0462.73ce.be20 ARPA Vlan1
Internet 185.51.204.29 178 0007.7d37.8282 ARPA FastEthernet4
Internet 185.51.204.30 - ecbd.1d60.afbc ARPA FastEthernet4
Internet 185.51.207.121 - ecbd.1d60.afb8 ARPA Vlan1
Internet 185.51.207.122 0 Incomplete ARPA
Internet 185.51.207.123 - ecbd.1d60.afb8 ARPA Vlan1
wafai#
Hello
interrestng - its seem to suggest 10.10.10.16 doesn't know how to reply - can you confirm that host has a default-gateway
can you ping another host in that 10.10.10.x/24 from that rtr?
you could try 10.10.10.255 source vlan 1
res
paul
Kind Regards
Paul
on your 'wafai' router, you have configured:
ip nat inside source list 1 interface FastEthernet4 overload
and
access-list 10 permit 10.10.10.16
There is no access list 1 (at least not in the configuration you posted). Can you check that ?
Also, what is 10.10.10.16 ? 10.10.10.10 I assume is the CUCM server ?
Hello Georg
Nat isn't.being initiated here as the static route back to 10,10,10,0/24 is being used. If nat was used then the OP would have to ping by the global outside address which is 10.100.100.x to communicate
There seems to.be a lot of ghost config on both rtrs not doing anything which is clouding the troubleshooting However to me ( i could be wrong) this is looking more like a possible host issue
if the OP can ping other hosts in that same subnet sourced from that vlan then we'll know for sure
res
Paul
Kind Regards
Paul
Paul,
it could be the host. It might be useful to see a schematic drawing including the physical devices and connections. With all the redundant config bits, it is indeed hard to troubleshoot.
10.10.10.10 cucm
10.10.10.16 billing
thank you
i changed server default gateway its working.
Hello
Glad to hear that-
If applicable, Can you please mark the post as correct so to possibly assist others in the future.
res
Paul
Kind Regards
Paul
So it was the default gateway indeed !
