Can't authenticate with Access point, asking for username/password
cshannahan
Hey all, I've configured quite a few access points before.  Mostly 1142's.  We have these other ones, 1200 access points.  I didn't configure them but I'm here troubleshooting why I can't connect to a WPA (tkip) network.  See the config below.  The config is pretty much the exact same as the 1142s but when I try to connect to the Secure-WLAN it asks for a username/password before the network key?  I have no idea why, I've looked through my config everywhere and it's the same as my 1142s.  The code on these are a lot newer but I'm not sure if that is it.  Please have a look!
version 15.2
no service pad
service password-encryption
hostname CNPB01
logging rate-limit console 9
enable secret 5 $1$VRwm$umrusCyYKsgQX87TjwWDW/
no aaa new-model
no ip routing
ip domain name heavy.local
dot11 syslog
dot11 ssid CN-Guest
   vlan 853
   authentication open
   mbssid guest-mode
dot11 ssid Secure-WLAN
   vlan 811
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 121A0A051E0E08557878
dot11 arp-cache optional
crypto pki trustpoint TP-self-signed-2948609350
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2948609350
revocation-check none
rsakeypair TP-self-signed-2948609350
crypto pki certificate chain TP-self-signed-2948609350
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393438 36303933 3530301E 170D3933 30333031 30303030
  34345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39343836
  30393335 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009904 5BB89D80 69F26EA2 F4A11BA5 4D93FC3D A9A99924 1AC9B2CC FA222791
  67E3BB85 2857F096 972BB98E 8B238C1E D63B5399 0B629D3B 68CA8012 BCDD554F
  48A347D8 30104959 29EA1348 FC7F1414 E25E9A96 5EC0E8D3 DB74C6B4 2BF36794
  3B9A585D 32BF1A73 04683F40 C5EF75D3 D1722CEB B2EB2648 DCEF43FC B54330E4
  EA750203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 145EA774 02B0EE1F 8E603C3B 57E8065E ED0263A3 47301D06
  03551D0E 04160414 5EA77402 B0EE1F8E 603C3B57 E8065EED 0263A347 300D0609
  2A864886 F70D0101 05050003 81810085 9EE1EBB7 6AE73F4F CA06C892 516C8F22
  0243812F B3FE0F01 35FC12F3 C099423E 2FCFC693 E72CEC2F 33F95D18 C705BCC9
  14B16C02 16C2D7AA F824CB77 1C362992 F0FAC363 6D9C7525 DF949985 B809CB7A
  320CE4D9 B66274B8 646F748C D632E283 09E0B76A 7FDB9766 317504B4 F1CB442F
  008E1BCB 5E570B96 BB84EB6F CC6585
        quit
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 811 mode ciphers tkip
ssid CN-Guest
ssid Secure-WLAN
antenna gain 0
stbc
mbssid
channel 2432
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.811
encapsulation dot1Q 811
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 spanning-disabled
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
interface Dot11Radio0.853
encapsulation dot1Q 853
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 spanning-disabled
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid CN-Guest
ssid Secure-WLAN
antenna gain 0
dfs band 3 block
stbc
mbssid
channel 5745
station-role root
bridge-group 1
interface Dot11Radio1.811
no ip route-cache
bridge-group 254
interface Dot11Radio1.853
no ip route-cache
bridge-group 255
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.811
no ip route-cache
bridge-group 254
interface GigabitEthernet0.853
no ip route-cache
bridge-group 255
interface BVI1
ip address x.x.x.x 255.255.254.0
no ip route-cache
ip default-gateway 172.16.206.1
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community public RO
bridge 1 route ip
line con 0
login local
line vty 0 4
login local
transport input ssh
end
cshannahan
Just a little update.  On my Windows 8 laptop I get the username/password prompt.  I can enter anything in there and then move to the next step, I then enter the network key for the SSID and I'm on the network.
When I go to someone who has a Windows XP (I believe) PC it just gets stuck on validating identity. No prompts and they can't connect.
We shouldn't get anything but a network key prompt, so I'm a little stumped.
I read this in the release notes.
When Cipher Is TKIP Only, Key Management Must Be Enabled
When you configure TKIP-only cipher encryption (not TKIP + WEP 128 or TKIP + WEP 40) on any radio interface or VLAN, every SSID on that radio or VLAN must be set to use WPA or CCKM key management. If you configure TKIP on a radio or VLAN but you do not configure key management on the SSIDs, client authentication fails on the SSIDs.
So I changed the encryption to WPA CCKM and WPA2 but I'm getting the same thing.  It's asking me for a username and password before the network key, same happened to another user with a MAC.  I took the encryption off and everything worked great.  This is frustrating.
This has to be buggy software.  Any help?
