Can’t delete in read Only file system
mederkolly
Good evening I am deleting customer information a Cisco switch. I hit the mode button to enter rommon and then enter the command
The issue is the file system is read only
“Set Switch_ignore_startup_cfg 1”
Then I reboot switch enter “write erase” then reboot the switch again I go BACK into rommon then try and delete the file and it continues to say “this is a read only file system” what have a done wrong?
Mark Elsen
        - Post the exact command of the file you are trying to delete and the resulting error ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
