can't ping ip on Interface vlan
warmanovic
hi All..
i have tried to add new IP MGMT to our switch..and the old IP MGMT still on the config
i have created vlan 9 for the new IP MGMT, and also add ip address on it:
interface Vlan9
 ip address 10.170.40.19 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip flow egress
and here are the old IP Management:
interface Vlan5
 ip address 128.236.96.239 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip flow egress
but until now, we can't ping or telnet to new IP MGMT from another sw/router...
is there any wrong with the config(please check attachments)?
there is no restriction from our Firewall to access that IP.
please help...
Thank you
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi,
do you have routing (static or dynamic) for 10.170.40.0/24?
try to add this:
no ip route 0.0.0.0 0.0.0.0 128.236.96.3
ip route 0.0.0.0 0.0.0.0 10.170.40.x
Hi John
is it ok right, if we put both " ip route 0.0.0.0 0.0.0.0 128.236.96.3" and "ip route 0.0.0.0 0.0.0.0 10.170.40.x" ?
hi,
no, the L3 switch will load balance between the two default route.
also make sure the design of your switch will do Layer 2 or Layer 3 (routing).
if it's only L2, the you just need the ip default-gateway 10.170.40.x command.
it will do layer 3
if i erase the ip route 0.0.0.0 0.0.0.0 128.236.96.3
and the command :
interface Vlan5
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip flow egress
will not function anymore right?
because we can't ping 128.236.96.239?
please advise
yes, you might lose remote connection.
i would suggest to do it on a maintenance window.
